If you take the time to do some searching many if not all of the questions you ask have already been asked and answered so assuming you do a search of SAU here is the one of the best links that should fix your issue very cheaply. If you take the time to add to these threads it remains as a quality database for the next person with the same issue.
http://www.skylinesaustralia.com/forums/in...t&p=3587533
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5058966
Mate I've got Splitfire packs in mine. When i was looking at doing the swap i talked to a couple of workshops and alot recomended superspark as a cheaper alternative to the splitfires. Haven't heard much about the yellow jackets, and also the JJR ones Just Jap sell so i would stear clear. unless someone can recomend them. but unless they have been in a car for a couple of years you cant realy give a good opinion.
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5059915
i had jjr coilpacks in my 32
but it came with them so i dont know any difference from the stock ones
i've heard good things about the yellow jacket ones so i'd go with those as a cheap alternative
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5060894
I have only heard good things about yellow jackets too so i reckon i will go for them
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5061322
Anybody got a set for sale? I have looked at yellow jackets, supersparks and spitfires but i am pretty broke
Try wolverines method and if that isnt effective try second hand factory items.
http://www.skylinesaustralia.com/forums/R3...ts-t305560.html
Mine were pretty rooted after 10+ years of use and I opted for the proven super direct ignition system and didnt stuff around with other inferior brands.
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5062615
Thats pretty much why i went for the Splitfire straight away. I know now that the will last the rest of the life of the car. No matter what mods.
https://www.sau.com.au/forums/topic/305793-coilpacks/#findComment-5065525
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
