Hi Guys...
I have spoken with andrew, and he assures me they're juuuuust about done: ready to go into the oven ( I assume for undercoating)...
Apparently we should expect them on our doorsteps mid February. He has apologised profusely for the delays so far, and said he'll be in more regular contact from now on (although exactly how much we will need to know in the next 2 weeks is a moot point...).
So, there you have it.
To anyone else who's interested, I'll be getting my kit fitted pretty much straight away: I'll post pics when it's done! :)
https://www.sau.com.au/forums/topic/305804-roof-rail-replacement-kits/
  • 3 weeks later...
Ok: just spoke with him again, and there will be a small delay (as usual): He has assured me he is onto it (we had quite a long and informative chat), and they will be ready ASAP - within the next couple of weeks. Patience, peeps!
I'll keep you guys in the loop as things develop.
  • 2 months later...
I have contacted Andrew again, as there was no word from him, and the kits were at least a week overdue after his last expected date.
Long story short, he is HOPING to have them ready for shipment mid next week.
Getting frustrated now...
Haha... It has been a very long ordeal. Im sure everyone including myself will be stoked once we get them. Have you had your roof rails out this entire time waiting for the replacments?
I chased him up 2 days ago as well
Stagman, we will get ours sent up togather to save postage.
I've had them off for over a year now: this whole thing started when another Gold Coast workshop stuffed me around for 7 months, after quoting me 2 weeks to modify the rails I bought from Japan.
Note to all who buy the kit: I discovered some light surface rust on the roof under where the rails sit, and am unsure (and doubt) if the original removal of my rails caused it: could be like the "rust under the mirrors" problem - if the rest of you guys find the same thing, then we can assume it's another common issue....
..Eeek
bugger!! maybe if these rails ever get made i better get a set so i have an excuse to check for rust
watch this space: mine will be fitted and painted as soon as I get them.
Guys
Andrew needs to know if your car has sun roofs, as they will need different mounting bolts to cars without.
An email has been sent to let him know
PS
My car had NO rust under the rails
  • 4 weeks later...
ok: He's finishing up the kits today or tomorrow: he has promised to send pics of the finished product asap. Assuming we're all happy, we can then pay the balance, and they should be on their way to us late this week/early next week...
  • 3 months later...
what ever happened to this?
After 13-14 month wait they turned up last week.
I have tried a quick fit and they fit like shit. Not too happy with them
Will be a couple of weeks before I get time to refit and rework them.
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
