fellas im having a hard time with w c35 laurel did an engine swap and make sure the wiring was good for the tranny, but the tranny pulls off on third and doesnt change any gears, i know that the wiring is very important for this to happen but checked everything but nothing......So i plugged in my carman scan tool to the obd1 connector and when i scanned the tranny i got CODE 10 VEHICLE SPEED SENSOR ENGINE & CODE 17 FLUID TEMP SENSOR
now the speedo on my dash goes to about 80 an then falls of to 0
Im thinking if i change the speedo it might fix the problem but there is this fluid temp sensor code 17 that makes me feel i might be wasting time, thinking that the fluid temp sensor might be inside the tranny and thats a whole different i wouldnt really venture so far
i need some advise ASAP!!!!!!
Thanks
https://www.sau.com.au/forums/topic/305807-rb-20de-neo-tranny-issues-need-help/
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
