so today had my hicas lock bar and wheel alignment done by ken at accurate suspension services here in brisbane.
He has told me to get my car going straight i'll need some arms to adjust castor. (car is pulling to the left)
He recommended i use some adjustable rose jointed arms as they will allow the most adjustment.
I expressed my concern about running rose jointed stuff as ive read here many a time its no good for the street. (my car is a daily)
He mentioned i could try the adjustable super pro bushes and they "might" just get me enough adjustment to get it right.
I would like to know my options here. I'd rather use a rubber type mount if possible.. are rose joints that bad? Stay away from pillowball im guessing?
What brands are best and where should i buy them?
For example... could i use something like this?
http://www.rhdjapan.com/ikeya-formula-stre...-350z-2wd-50338
i really dont want to spend 400 odd dollars on something like cusco or ikeya or whatever as its only a daily driven r34 gtt that will at most see the track once or twice a year.
Ideas?
Cheers
https://www.sau.com.au/forums/topic/305813-castor-armtension-rod/
If u don't wanna spend much, just get SuperPro offset bushes. If want more caster which will feel and handle better, go with Kazama ones. They're high quality and have dust boots on the rod ends which will make em last way longer. They're around the 300 dollar mark.
thanks mate.
Yeah i saw those kazama ones $255 from rhd apparently. does anyone stock them in Aus?
superpro bushes are roughly $130ish i think so not a huge difference.
what about stuff like the JJR items?
i put white line adjustable castor bushes ($140 NZ) in my stagea and it made a huge difference . youll find if you drive on the wrong side of the road will pull right. lack of castor makes car follow camber on road .now my left is on max which got me 4.25 degrees of castor and right is on 4 degrees and its mint as .
apparently the superpro bushes give more adjustment then the whiteline?
sourced a set of kazamas for 265 posted. so i think i might get these.
just dodgily checked my toe:
right front - can fit my 3 middle fingers in easy between back of tyre and mudflap.
left front - can only fit 2 and a half if that in between back of tyre and mudflap.
so quite a difference
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
