hey guys, ive tryed the search, but cant find the answer to what im after.
ive got a few mods...and with them i have a stock ecu...now im not big on cash so i want to know whats the best/cheapest option of getting my car tuned and where. thanks
https://www.sau.com.au/forums/topic/305867-ecu-question/
pretty much u cant if u have a r33.. no one will touch them and Nistune dont make a board for them..
U have to get a r32 ecu, then nistune it, then get ur variable valve controller installed as well..
after all this is done, ur better off just getting an Apexi PFC for ur Car, and having a much better / through tune.. I know Dr.Drift does this, and he charges arround $1,200... So by the time u pay all that may as well get an Apexi for $1000-1,300 and get that tuned up :P
I went through the whole weighing up all the options like this too, but Apexi PFC came out on top, that is probably ur best chance of getting a good decent tune. Without all the f**king arround to do with a r32 ecu, because in the event that u get EPA'D it will be much easier to swap straight over... And you WILL get EPA'd its just a matter of time..
Anyway my 2 cents on what i did and why i did it, but best of luck to you.
https://www.sau.com.au/forums/topic/305867-ecu-question/#findComment-5059275
the best and cheapest i can think of is an SAFC
the PFQ FAQ in my signature covers the differences between the SAFC and PFC
if you are ok accepting what the SAFC does and its results it would be cheaper for you vs PFC
https://www.sau.com.au/forums/topic/305867-ecu-question/#findComment-5060061
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
