Ok i have a power fc, i used paulr33 excellent faq and i know how i need to correct for the larger injectors i have (1000cc) but do i need a retune one i install them or no ? i am changing NOTHING AT ALL but the injectors, no more boostr nothing, i do have a larger turbo i will be installing, but right now i just need car moving any advice ? and of course once i install the larger turbo i will be getting it tuned !
https://www.sau.com.au/forums/topic/305905-pfc-larger-injectors-install/
Hook up a wideband O2 and just keep an eye on the A/F, I find with larger injectors from factory it just richens heaps on full load.
but if you're driving the car under 4000rpm you should be fine provided it's not stupidly lean
just imagine the injectors are physically bigger. they work off the same voltage as your old ones so all that changes is pulse timing and width. so if you have gone from say 500s to 1000s, at the exact same tune state they will literally run twice as rich.
the most common mistake i see with injectors is people thinking that they could just put a bigger set and not need to do anything else, that and adding an FPR can fix anything.
its all a learning experience, your doing well mate :P just spend some time retuning em and it will all add to your experience.
Since you will have setup the PFC to cope with the new injectors, the tune should be fine for driving between workshops (no boosting). If cold start/cold running is not ok then something is amiss (for example you didnt enter the correct latency when updating the PFC)
You may even find its ok without a retune, but you need to verify that on the dyno first.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
