Hi guys & gals,
I'm getting an issue with my 34GTR where the 4WD and A-LSD warning lights are coming on the dash and the car is only running RWD.
It was thought that the PowerFC was faulty and the cause of the issues and so the stock ECU was put back in the car last week.
The issue seemed to go away and all was good until two days ago it started happening again.
So it seems the PowerFC wasn't the issue and now I'm hoping people here can help me diagnose the problem!
Things to note:
- I usually find out if the car will be 4WD or RWD when I first start the car. The light either comes on or doesn't come on within the first 2 seconds of starting the car.
- If it comes on then I can turn the car off and start it again until it doesn't come on.
- I've noticed that if I start the car and give it a bit of revs, then it doesn't happen.
- Sometimes in traffic when I decide to turn on the A/C or rear demister or even the headlights, it makes the 4WD/A-LSD light come on and then the car is in RWD again.
Battery is brand new, fitted 8 days ago, no voltage issues that I can see.
Does anyone have an Electronics Parts Guide that I can see the sensors to check?
Hoping to get to the bottom of this, it's frustrating :P
Thanks guys!
https://www.sau.com.au/forums/topic/305926-r34-gtr-4wda-lsd-lights-on/
I found this
http://www.skyline-owners-club.com/forums/...tessa-code.html
And for the Attesa codes.. just got to figure the instructions for R34. Hopefully I can do it this weekend.
http://tyndago.googlepages.com/gt-rattesainfrormation
Edited by UnCo
based on what youve told us so far id say TPS could be a likely culprit
both systems need the TPS signal (even at 0km/h) to run and pass diagnostics
if TPS is unplugged, broken, out of range, then the system fails and the lights come on
the TPS signal comes from the throttle body sensor
then runs into the main ECU harness into the main ECU
from here the ECU relays the same TPS signal onto another wire, which runs to the boot
and feeds into the 4WD/A-LSD computers. check the wire # on the engine wiring looms
ive seen my TPS go out of range and cause my A-LSD to fail like yours does
a known fix that I have seen (like yours) is to mash the accel pedal a few times
this manages to clear the out of range TPS signal and return it to normal state
TPS should 0.35v ish at idle (ie nothing on the pedal)
Hey Paul,
I had a feeling it could be that.. the throttle sensor display has been rather irratic on the MFD (when I hold constant throttle at say 20% throttle, the display shows it jumping between 18-22% whereas if I hold the throttle at a constant in the TPS calibration, it stays steady)
Trent down at Status Tuning said that he was getting a TPS error code but when we ordered a new TPS from Nissan and put that in, it didn't have any changed effect?
So you mean try mashing the accelerator pedal when in idle or something?
check the actual wiring of it
with mine
if i boot the car up and drive around shortly after TPS goes to 0.00v
A-LSD and SLIP fail and the engine revs to 1500rpm and stays there (as it panics because TPS is dead)
so i turn the car off, mash the accel pedal a few times (to quickly open/close the throttle body) and then re-start the car and it's fine
if youve replaced the sensor, i would check the wiring
  • 8 months later...
  • 6 years later...
    • https://www.carsales.com.au/cars/details/2002-holden-commodore-ss-vx-ii-auto/SSE-AD-18219062/?gts=SSE-AD-18219062&gtssaleid=SSE-AD-18219062&pageSource=details
    • does anyone know tie rod torque setting and anti roll bar for r34? Is there a workshop which shows various components torque setting?
    • Hi    have purchased pair of eibach wheel spacer as I couldn’t fit set of wheels I bought for my car due to it catching caliper.   I know I need to cut the bolts on my discs so they sit flush with the nut supplied but the nut doesn’t sit all the way into the groove meaning wheel would not directly fit onto the spacer rather the nuts. Any thoughts?   See pic   https://ibb.co/VJK5w5G
    • Nah. There's not shit tonnes of pressure in there. Just drill with a 1.5mm drill or something equally tiny. When the drill goes all the way through thee gas will start to come out, but with such tiny path through the flutes of the drill bit, it won't be at all dangerous. You can be as paranoid as you like from then on. I'd just pull the drill out while keeping my face out of the line of fire. But then, I spend half my time looking into pressurised furnaces. So my risk acceptance is somewhat higher than most!
    • Been needing a new clutch for a while, but holding off because of life tingz and adulting. But... Being of Asian descent, I can't pass on a good sale, especially everyone else is selling it for $2k+ (JJR has it for $1799). Really on the fence on this one, because the unsprung version of this is $1281 via Shitbox (Sparesbox) and the sprung version is quite a bit more (no idea why Shitbox doesn't offer them). Ending up just sending it and getting the twin sprung organic. Mainly because I wanted the car to be nice to drive and didn't want to make it more of a shitbox than it already is.
