I am interested in putting a switchable system in the car, whereby by switching a solenoid a valve will effectively 'turn off' the BOV. Why - as my HKS SSQV is hidden behind the bumper, if i am stopped by cops then i can switch off the BOV avoiding defect.
Some basics on BOVs:
BOV is triggered by a boost feed from the inlet manifold, when idling or accelerating, the pressure on both sides of the throttle are equal, therefore the BOV remains closed. When there is boost and the throttle is snapped shut, there is vacuum in the intake manifold vs. boost on the turbo side, therefore the BOV opens.
So, if I can install a vacuum hose that always sees turbo side pressure, and have the BOV feed to be switchable between the inlet manifold side and turbo side vacuum hose pressures, then when
1. it sees the intake manifold pressure it will operate
2. it sees the turbo side pressure it will remain closed at all times.
My questions are:
1. is this actually possible (switchable in cabin)
2. where would i take the turbo side vacuum hose from?
3. does anyone know if i can get a switchable valve ie. a t-piece that can be electronically switched so it is possible to switch between the inlet manifold side and the turbo side pressure hoses?
4. does anyone actually understand what i am talking about?!?!
Thanks, and I hope that is clear!! :thumbsup:
https://www.sau.com.au/forums/topic/30594-silencing-the-atmo-blow-off-valve/
You can fit a Tee in the line that gives the bov a signal and a tee in one of the lines coming off the comp cover and link them with a solenoid in the middle. Switch it open/closed as required and your valve wont open when the solenoid is open as it will be seeing the same pressure on both sides of the piston.
This is fine if you have a factory airbox which will muffle the sound of reversion.
If you have a pod you will hear the lovely reversion flutter which may be louder than your bov anyway.
So basically, yes you can do it but it may not be worth the effort.
Guest RedLineGTR
nah the GFB Stealth FX u have to adjust with your hands. even if the cops see a bov with a trumpet they will assume it vents to atmosphere. but if they cant see it then they get u to rev it and hear nothing u will be in the clear.
Try mucking around with different hoses etc see what the car reacts too. But i've seen cops find bov in bumpers, hiden behind airboxs etc..so they might find it anyways.
What gives them the right to feck about with whats under the hood? If they change something that makes it defective, isn't that just dodgy as hell? I wouldn't be letting any cop mess with hoses under the bonnet... In a diplomatic way of course.
Isn't the defect for the bov just for the fact that it's installed, not for whether or not it's doing anything? Either way I'm sure the cop would just assume it was there and working, if they saw it, even if you tried to prove that it was off.
Ah fair enough. I'm lucky that my bov doesn't go off at low boost, so whenever I see a cop I just drive sedately and he hears nothing :P You'd also have to do an indepth search to find it, so if I did get pulled over I don't think I'd get done (touch wood).
Ronin 09 go and see a LPGas workshop and get a high flow solenoid, fit this in-line on the existing vac/boost hose to your BOV. When energized the BOV will operate normally when swiched off the bov will cease to operate. I'm sure this would work..... Give it a go! :P
Danny, don't you need to show the BOV line the same pressure as what the diaphram is seeing (ie pressure of the intake pipes) to keep it closed? I'm not sure what you mean by the high flow solenoid being energized..?
I thought so too, but if you get a set of pliers in one hand and squeeze the hose on the BOV while revving the motor with the other you get no psssshhhh, let the pliers off and rev...psssshhhhh! if you fit a highflow gas solenoid to this hose when it has no power the solenoid is closed so there will be no pssshhh. when you power it up (energize) the solenoid opens and allows the BOV to operate normally. so you would use an ignition power supply via a switch to the solenoid and the other solenoid wire to earth. Make sense??
    • Yeah everyone always seems to refer to them as S13 wheels however they came on R32 Skyline, A31 Cefiro, C33 Laurel etc., and also came polished diamond cut or painted depending on the model. Congrats on your GTS purchase! I'd personally leave it NA.
    • In this thing about this 100% renewal energy stuff I hear no one really talking about anything other than power and fuel really Power and fuel, whilst being a huge part of how we use the billion year old Dinosaur juices, are only 2, of the probably thousands of things that we need to use it for in the chemicals industries for making nearly everything we use nowadays I'm all for a clean planet, but if we want to continue to have all the day to day appliances and stuff that we rely on everyday we will still need fossil fuels Whilst I do love science, and how it can bring innovation, there's really a limit to how far it can go in relation to "going green" As for EV's, unless your charging of your own solar panels, it isn't helping the environment when you consider the the batteries, the mining processes required,  the manufacturing process required, and how long a batteries (read: the vehicle) lasts long term If I was supreme dictator of the world, I would ban the use of sugar for fizzy drinks and food additives and use that for ethanol manufacturing, petrol engines would be happier, and people would be alot healthier  Disclaimer: Whiskey manufacturing would still be required, so says the supreme dictator of the world Same same for all the vegetable oils that get pumped into all our food, use that for bio diesel Disclaimer: the supreme dictator would still require olive oil to dip his bread in This would take some of heat off the use of the use of fossil fuels which are required for everything we use, unless you want to go back to pre 1800 for heat and power, or the early 1900's for plastics and every thing else that has come from cracking ethylene  Would I be a fair and just dictator, nope, and I would probably be assassinated within my first few months, but would my cunning plan work, maybe, for a while, maybe not Meh, in the end in an over opinionated mildly educated arsehole typing out my vomit on my mobile phone, which wouldn't be possible without fossil fuels And if your into conspiracies, we only need the fossil fuels to last until a meteor hits, or thermonuclear annihilation, that would definitely fix our need for fossil fuels for manufacturing and power issues for quite some time  Meh, time for this boomer to cook his lunch on his electric stove and then maybe go for a drive in my petrol car, for fun
    • It really helps that light duty vehicles have absolutely appalling average efficiency due to poor average load. Like 25% average brake thermal efficiency when peak is somewhere around 38% these days. So even a 60% BTE stationary natural gas plant + transmission and charging losses still doing much better with an EV than conventional ICE. And that's before we get into renewables or "low carbon nonrenewable" nuclear which makes it a no-brainer, basically. In commercial aircraft or heavy duty diesel pulling some ridiculous amount of weight across a continent the numbers are much more difficult to make work. I honestly think in 5-10 years we will still be seeing something like the Achates opposed piston diesels in most semi trucks running on a blend of renewable/biodiesel. Applications where the energy density of diesel is just too critical to compromise. CARB is running trials of those engines right now to evaluate in real world drayage ops, probably because they're noticing that the numbers just don't work for electrification unless our plan is to make glorified electric trains with high voltage wires running along every major highway and only a token amount of battery to make it 30 miles or something like that after detaching. Transport emissions is not insignificant especially in the US, but yes there's a lot of industrial processes that also need to be decarbonized. I agree the scale of the problem is pretty insane but EDF managed to generate ~360 TWh from their nuclear reactors last year and this is with decades of underinvestment after the initial big push in the 70s and 80s. I don't think the frame of reference should be solar-limited. France is not exactly a big country either. Maybe it doesn't work everywhere, but it doesn't have to either. We just can't live off of fracking forever and expect things to be ok.
    • Yeah, all the crude is used for fuels and petrochem feedstocks (pesticides, many other chemicals, etc etc). But increasingly over the last few decades, much of the petrochem synthessis has started with methane because NG has been cheaper than oil, cleaner and easier and more consistent to work with, etc etc etc. So it's really had to say what the fraction either way is. Suffice to say - the direct fuels fraction is not insigificant. Heavy transport uses excruciatingly large amounts. Diesel is wasted in jet heaters in North American garages and workshops, thrown down drill holes in quarries, pissed all over the wall to provide electricity to certain outback communities, etc etc. Obviously road transport, and our pet project, recreational consumption camouflaged as road transport, is a smaller fraction of the total liquid HC consumption again. If you're talking aboust Aussie cars' contribution to the absolute total CO2 production of the country, then of course our share of the cubic mile of coal that is used for power generation, metallurgy, etc adds up to a big chunk. Then there is the consumption of timber. Did you know that the production of silicon metal, for example, is done in Australia by using hardwood? And f**king lots and lots and lots of hardwood at that. Until recently, it was f**king jarrah! There are many such sneaky contributors to CO2 production in industry and farming. NG is used in massive quantities in Australia, for power gen, for running huge water pumps (like, 1-2MW sized caterpillar V16 engines running flat out pumping water) for places like mine sites and minerals/metals refineries. And there are just a huge number of those sort of things going on quietly in the background. So NG use is a big fraction of total CO2 production here. I mean, shit, I personally design burners that are used in furnaces here in Oz that use multiple MW of gas all day every day. The largest such that I've done (not here in Oz) was rated to 150MW. One. Single. Gas burner. In a cement clinker kiln. There are thousands of such things out there in the world. There are double digits of them just here in Oz. (OK< just barely double digits now that a lot of them have shut - and they are all <100MW). But it's all the same to me. People in the car world (like this forum's users) would like to think that you only have to create an industrial capability to replace the fuel that they will be using in 10 years time, and imagine that everyone else will be driving EVs. And while the latter part of that is largely true, the liquid HC fuel industry as a whole is so much more massive than the bit used for cars, that there will be no commercial pressure to produce "renewable" "synthetic" fuels just for cars, when 100x that much would still be being burnt straight from the well. You have to replace it all, or you're not doing what is required. And then you get back to my massive numbers. People don't handle massive numbers at all well. Once you get past about 7 or 8 zeros, it becomes meaningless for most people.
