  • Replies 1k
Posted Images
O.K Phil. Diffuser doesnt fit as nicely on my car lol..... bit of an exhaust issue
What Exhaust did you have? my rear section hits the diffuser something shocking. And I'm guessing it wont take long for the carbon fibre to melt/burn/whatever
Mine sits pretty low, heres what I'm dealing with
It doesnt look to bad in the photos but in real life it looks pretty wonky. I'll probably either have to hack the diffuser up a bit or make some new brackets to push the sides down a bit I guess?
If I have to cut it I'm glad I bought yours second hand, would be sad if I had to cut up a new one lol. but thats gonna be last resort I think
Ah ok.
Yeah my exhaust kind of went up and out to an angle where as yours is more straight. Mine actually sat against the exhaust aswell but it doesn't damage the carbon at all.
Yeah just give it a bit of a cut underneath the muffler and should be all sweet.
To easy. mine is angled but it dips real low near the diff which is making it hard lol. think I've used a different mount on the rear to what you used as well to get it to fit
Will have a play anyway
Beeeeeeeeeen ages since I was on here! doesnt look like much has changed.
Callan, buy my spoiler blade. - carbon one I got from Phil. taking up space so I want it gone.
Phil - A Pillar, 52mm pods. Carbon. Get me one, yesterday?
Would love to get one that was still the same ABS plastic as factory.....
may even get it copied :/
Edited by Force Fed
Does Phil even go on now he has his new toy? BTW any one got a rb25 turbo for sale?
I dont know if he's been coming on. Going to text him through the week as I should be seeing my wideband and boost gauges rock up. Along with some other things from the states.
May even be seeing another shipment rock up this week too! YEWWWWW
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
    • This makes sense. I have 2 so I'll just choose the least favourable child to perform the task.  If all turns to shit, I've still got a spare.  Win-win!
