  • Replies 1k
Posted Images
I'll PM when the car is off life support...
rods pistons n head studs got here today. WIN! 4 days or so from the states (not including weekend)
Phil - Did my email come through last night?? not sure if it sent properly, might of done it twice in fact
Edited by Force Fed
Yeah man got it. Will hopefully let you know some info in the next couple of days.
Glad to hear your getting a bike Phil. Will definitly have to go for a ride when you get it.
Yeah I miss not having a bike. Very much looking forward to the R6 :)
What is peoples take on this, just got this done 20 mins ago.
The dyno operator mentioned that its running rich, I had an inclination towards this, but wanted to confirm my suspicions. Leaving flame work everywhere was a good indicator though.
What do the standard RB25 run as far as AFR levels?
Main question really, is it reasonably safe?
Car is running 10psi of boost.
is that on stock ECU?
10.5:1 is pretty rich, mine ran about 10:1 on stock ECU back in the day
around 12:1 is what you want (in short, its not as simple as 12:1 everywhere, but roughly that)
Its a good result if your running stock ECU, I made 141rwkw on 8psi with the stock ECU, hit R&R real bad on anything above that
Nah running Power FC
The dyno operator didn't sound keen about it being so rich and suggested a tune.....to the tune of $600
How 'un-safe' is it to be running as rich as this? Or is he just trying his charm on me?
Eventually I do want to run around the 12-14psi mark, already got a walbro, but first got to save up for the injectors.
Don't run 12-14psi through the stock RB25 turbo (It's the stock turbo yeah?) or you will blow out the exhaust wheel into the cat. Especially with it coming into summer.
If it is the stock turbo you don't need injectors at this stage.
That AFR on a Power FC definetely needs a tune.
I ran 12psi on stock turbo for over a year without any issues, but I know others that havent been so lucky, I'd stick to 11psi.
Its not un-safe to be running 10.5:1 AFR's, quite the opposite really (unless hes checked a bunch of timing at it)
See where your power starts to drop and notice that its also where your AFR jumps to 10.5:1 This is where you will be losing your peak power unless you have exhaust/intake restrictions or some other kind of issue. How does the plot for your boost look? (If they gave you a power vs boost graph)
If not and you want to know, the dyno run should be stored in there dynos computer and you will be able to go back and get them to print one out (assuming the plotted the boost, which they should have)
luck of the draw on turbo's but it's a timebomb IMO :)
Yep, stupidly rich. I'd almost say too rich, it would want to flood the chambers a bit.
Nice power though!!!
Keen as f**ken mustard to see the results of yesterday!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Edited by Force Fed
Nope unfortunately not. Have decided I shall be parting my car out (have allready began selling one or two things). At this point in time the money invested into that car can be better used so it has to be done. Never thought this day would come to be honest lol.
And yes Chris, you can have my title :P
:O
don't do it phil, you'll regret it.
:O
I'll be sad to see it go. But gotta move on. House is the priority at the moment.
Robbo's right Phil you will regret it and you'll never make your money back.
Nah definetely won't make it back. However should get a decent amount back by parting it out. I've calculated what I should roughly get back in the parts that I have put onto it alone and it's a decent amount.
Parting out can make quite a lot back, I've done it before.... Time will tell :)
Phil - Carbon A Pillar + 2x52mm gauge pods able to get em?
The carbon A pillars might get ruined trying to take them off?
    • That M3 looks like it handles so well, initial slight understeer on turn in followed by oversteer which is cancelled out as steering returns to centre. Looks like such a fun car to drive. In comparison the Skyline and Sierra look like they understeer more and thus need more heavier steering inputs...?
    • Gday   on the hunt for an rb25 gearbox and clutch to go into my R32 rb25/30 build happy to travel a bit or pay for freight for the right one From my limited research, think I need an rb25 driveshaft yoke to make it fit so I’m after one of those too located Bathurst
    • Common for single gauges to be swapped around. My 33 GTST when I bought it had a GTR tacho fitted, everything else was GTST gauges.
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
