  • Replies 1k
Posted Images
how much callan ??
Undecided yet if im def going to upgrade. its either spend $650 on the HKS turbo and get around 280rwkw with good response or sell it and go a hypergear and get between 300-350rwkw with a bit more lag......
I like the response, but its a big power jump
go the hypergear. response is over rated.
yeah lag is hated on soooo much and its bullshit. lag is f**kin awesome cal
drive around on boost and smoke most cars that would try race ya
Well te idea with the HKS was I would have a good balance of both, Plenty of people were getting 280rwkw + on pump fuel with rediculous response, go to E85 and they were over 300rwkw
But things didnt pan out that way, pretty angry with the lack of support from HKS (through nengun was probably the issue)
So its looking likely I'll end up with the Hypergear, and sell my HKS turbo on ebay for more then its worth
But I'm waiting for Stao to finish his latest research with the possible next gen of turbos. The amount of evoloution they do with there turbos makes it hard to settle on a turbo when a newer better one will be made soon. Variable Vane turbo would be the go :thumbsup:
whats left to sell ??
Greddy turbo timer
Polished oil catch can with breather filter and braided lines and fittings
Nismo/Tomei fuel pump kit
Pivot Raizin Voltage Stabilizer and earthing kit
Chrome dipped and smoothed RB25 intake runners
Cooling Pro 40mm polished alloy radiator
NOS universal wet kit (50-150HP jets) with half filled bottle
NOS purge kit
Turbosmart fuel pressure gauge and adaptor for braided lines
Exhaust manifold
CAS
Blitz AC white faced boost gauge
Blitz AC white faced exhaust temp gauge
Alpine 640W 4 Channel Amp
Brand new carbon fibre RB26 coilpack cover
Brand new carbon fibre R33 GTR wing end caps
Rear S2 seats
That's all of it :)
Do you cry a little bit everytime u look at your dp? :P When are we going for a ride Phil?
Haha nah i'm good. Do miss it every now and then though.
Whenever man. I have Saturday off if you wanted to go then.
phil where did you get all your braided line & fittings from?
i will be keen for a ride when i get my new bike up here & rego'd :D
enjoy ya weekend, i am off to brissy for SOUNDWAVE :action-smiley-069:
Through Autobarn. I will actually start to carry braided line and also fittings on the shelf :)
Just trying to decide on what brand to carry. While Speedflow is the obvious choice it is also one of the dearest. The stuff I had on the Skyline was cheaper and I couldn't fault it so might carry them.
My Performance section will hopefully be exploding in size and stock over the coming months so keep your eyes peeled :D
Will do Chris, will add it into the next order. Haven't really had much to do with the carbon side of things due to parting the car out but now that nearly everything is gone I can start concentrating on that again.
are you able to get the push in male fittings for rb26 covers?
might have to get ya to come over and give me a hand to sort out what i need to get to do everything.
i don't need to buy any more go fast bits. i could probably open my own shop at the moment with what i have here now.
Yeah I remember the location is what I want.
as per text, any idea on 52mm version of your pillar?
edit: nevermind already sorted LOL.
Edited by Force Fed
Hey guys, just found this thread. Only recently got myself an R32 GTR. Live in Townsville too. I have seen a few skylines kicking about. Mine is gun metal grey with grey/silver wheels with a loud ass exhaust.
Unfortunately my car is off the road just now due to the engine being f**ked... But will hopefully get a built engine in it as soon as possible. On that note, does anyone have a suggestion as to where I can get a rebuild done with forged internals, etc...?
Hey man welcome to the forum.
Get one built down south. Plenty of places to choose from. Really depends on your budget and how much you want to do while the engine is out. Unfortunately can be quite the expensive exercise.
Did she spin a big end bearing? Or crack a piston ring?
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
