Townsville Skyline Owners
Gough R34 GT-T
  • Replies 1k
Posted Images
Hay guys, I know that this i a bit off topic but i new to the hole import scene, I had bought a r33 a bit over 12months ago and have decided to get it tuned up. I put it into today and it had come out with less power then it went in with. So now I am looking for someone that is a good tuner, I'm using apexi power fc. Any help would be much appreciated.
WHAT THE f**k HAVE YOU DONE....
ur dodgey wiring??
no dodgey wiring in my car mate.
happened at a workshop, welding earth arked out on some wiring .
wow sad to hear Rob. Any ideas on fixable? or what caused it?
fixable, workshop is going to fix it but may take a while. need another cars whole interior plus gtr seats, defi's, stereo, profec b, front widscreen ,window tint, some window trims and we still haven't seen under the whole dash yet.
but it will be back bigger and better, got some brembo's on the way and factory aero kit to go on :)
which workshop you go to?
what mods and power?
its fairly hit and miss up here but getting better.
I went to dynolink
the engine has all forged internals
stage 1 cams (not sure what exactly they are)
gt 35/40 with external gate
custom plenum and front mount
apexi power fc ecu
also has sard 880cc injectors
before i had it at dynolink it was around 400rwhp and now its 333rwhp and it running worse then it was. I was thinking of going and having a chat to Paul at extreme.
Edited by slick 33
Hey guys just look for this 32 number plates 90NER I sold the car to a guy in Townsville about 5 years ago trying to find out whats going on with it now, if anyone how's that would be great ,cheers
Matt
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
