hey guys thinkin of puttin an vg 30 turbo in my 33 s1.5 do u think it would make much of a difference? would i have ot change many other thing make it run ok? also how hard would it be to install im pretty good when it comes to cars and stuff
I think it would be challenging to get 270 Kw's worth of exhaust gas through a VG30 turbine housing .
You can look at a VG30 BB turbo as almost an R33 one but with a slightly smaller compressor wheel and slightly larger ratio turbine housing . They were designed to be a basic low boost turbo upgrade for the 3 liter V6 hence the larger turbine housing for the same sized turbine .
Best performance option using std Hitachi bits is to exchange the turbine housing on the 33's turbo for the VG30 one . Largest turbine housing , 33's turbo already has the larger comp wheel thought the 34GTt may have a larger compressor housing , can't remember .
Cheers A .
The turbo i have on my car now did 260 on another car when it was first made.
By the time you rebuild it and spend the money on a hiflow you could of picked up a decent KKR turbo that would outperform it easily.
Have a search through the forums for KKR, they are junk, need lots of boost for not much power and they are very laggy.
You just posted what a VG30 Turbo can be described as, almost word for word.
Compared to a standard turbo? yes you could, now go off and read what people think of the kkr after using one and then compare them to the views from people using a vg30 rear housing, i can gaurentee you a lot more people are happy with there vg30 than a kkr, whislt you at it research what happens when you put bigger bits on your standard turbo to get more power.
No need to research, have owned VG30DET/RB20/RB25/RB26 powered vehicles before.
Thanks for the tip though bud.
I thought the VG30det's got a .63 turbine housing. If its true high flowing it with a Cropped TA34 turbine with 52T 76mm or a 56T 71mm comp wheel using a .60 comp housing and a strong actuator should crack just over 270rwkws.
Disco - the OP6 housing of the VG/R34GT-t turbo can get to 270rwkw off the GCG items.
That is probably the utter limit though, i've never seen anyone post a more powerful result, most come in around 260-270rwkw @ 20psi give/take.
So that would seem to be the limits reached.
A GCG hi-flow of a VG30 turbo is going to be out performed by a KKR turbo?
:thumbsup: That is... Impossible.
Well personally I think you're better off using a Garrett GT30 turbine housing because they are designed for a GT30 turbine .
Also only the ball bearing T series turbos use those TB31/TA34 turbines , the real GT28 or 30's use GT28 NS111 turbines or GT30 UHP ones .
All there really is to gain by using a VG30 turbine housing on a Garrett BB cartridge is the std position and format dump pipe . If you go aftermarket then there isn't any reason not to use an aftermarket one for the Garrett T housing .
Again personally I would not buy an aftermarket "VG" style turbine housing when there is Garrett IW ones available and designed to work with their cartridges and wheels . Also the Garrett GT30 housings are made of high temp resistant materials for petrol apps , not so sure about the aftermarket VG30 type thing . Also available in a range of sizes too .
Your calls , cheers A .
Disco:
Since we are talking about the turbine wheels and obviously your self works in the turbo industry. Would you think the Factory Garrett GT30 turbine wheels would out flow the TA34 turbines with crop for high flowing applications? The GT30 turbine is obviously lighter in weight and spools faster. Just have to go through the trouble of installing a custom shaft for sleeve bearing high flowing options.
Actually I don't work in that industry .
I think the GT30 turbine was designed to be low restriction for its ~ 60mm size and the largish 84 trim size and high inducer tips seem to be the way to go about doing that .
If you wanted something in the generic T3/small frame T4 shaft size you gould look into the GT32 plain bearing turbines . I think these are in the 64mm OD range and from memory the trim size is a bit smaller than 84 . I have no idea how heavy they are and I'd say they would be in lower temp spec material being a diesel turbo .
Cropping or back cutting turbine blades is one way of removing some of the restriction but its also removing some of the sail area used to drive the compressor wheel . Again from memory TA34 turbines went up to 76 trim which is what the street crowd call stage 3 .
Maybe something else to look at is the turbine used in the Buick Grand National , a long long time since I've seen one but if still available at least they are a Garrett petrol app turbine .
The problem as I see it is that bush bearing high flows are difficult to get right because wheels big enough to make adequate grunt are held back a bit by bush bearing oil sheer drag initially . I don't know if bush bearing GT series turbos are any better off in this area , maybe playing with a GT3268 or 71 cartridge could give the answer to that one .
Cheers A .
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
