R33 Gtst Into C210
Ok, so theoretically speaking.......
If you had a complete R33 gtst skyline at your disposal and a C210 coupe to play with what parts would you use off of the R33?
and how hard (or expensive) said parts would be to fit.
I have been scouring the net for info but most of it's a bit sketchy.
Cheers Dan
Honestly...motor and box is about all that's of use to you.
not much else will easily fit, even the diff is a right pain to swap in.
No piping(or very little of it) from the intercooler side of things will fit, so it will all have to be custom.
Front seat could be used but would require custom mounts/rails. much easier to buy aftermarket rails and seats.
So really, only motor and box.
that being said, its still worthwhile because comparatively the C210 weighs bugger all.
better yet, buy my rb26. :thumbsup:
cheers
Jason
front brakes only... rears arent even close.
and i dont know about the front swaybar, the front suspension design is entirely different with a single lca and macpherson strut(c210), and Double wishbone (R33)
cheers
Jason
ok thanks guys,
So S13 stuff seems to be the way to go for the rear suspension with r31 disc and calipers
What would be the best option for what will be pretty much a daily with maybe a track day thrown in.
I've got a set of the landcruiser/hilux calipers to go on the 240k struts with the vented verada rotors.
or should I use the r33 brakes on the 240k struts.
or get a set of s13 struts/coilovers for the front and use the r33 gear on those.
I'm not chasing anything to serious just want to utilise the best of what I've got to work with.
Would like to use the seats as making a set of rails should be fairly easy and free, I'm also thinking rack and pinion might be nice but also a major head f@#k but I'll look into that one.
You guys are a wealth of knowledge, thanks for sharing
cheers Dan
Yep, for the rear s13 coilovers and r31 brakes would be the go.
Not worth the effot to try and fit r33 brakes to 240k struts,
So either use your hilux set up
or change to s13 front coilover, hubs knuckle etc and use the r33 brakes on that. keeping in mind s13 set up will sit the car very low.
I know of a 240k running a s13 front swaybar, and gtr swaybars are a upgrade in a s13, so i reakon the r33 one should bolt up fairly easly. (may need custom link bars)
I like low so thats good, but it still needs to be sort of legal.
Been reading up on the r33 conversion but the dog leg bracket seems a bit ordneary to me, swaybar sounds good tho.
 Share
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
    • https://www.carsales.com.au/cars/details/2021-nissan-skyline-400r-auto-rv37/SSE-AD-17857548/ Well there you go
    • Chris won't reply. He doesn't visit the forum much anymore. You can try these guys https://www.facebook.com/autotainment/ They did mine many years ago
