Not sure where to post this but I came across a company here in in OZ that makes engine blocks and heads out of aircraft grade billet aluminium. Would be very strong and light I guess.
Wondering if anyone knows of a complete engine build using one of these? They are available for a number of engines types. SR20, 2JZ, 4G63 and the mighty RB26!! Even available to suit Chevy bell housings. Now thats not you average Commy.
No idea of price or much detail but could you imagine the benifits? Weight distribution on a GTR for one, and track durability. Any info or details of projects in the pipeline would be an interesting read.
Here is the link
http://www.bulletcylinderheads.com.au/billetblocks.php
https://www.sau.com.au/forums/topic/305996-billet-aluminium-engine-block-heads/
  • Replies 44
Very interesting! The weight savings would be fairly substaintial i would believe. 20-30kg possibly? What's a full RB with all accessories weigh, 250kg?
Edited by PM-R33
If an RB26 block comes in below five figures I would be f**king surprised. Absolutely super cool though! Money no object anyone...?
Ive sold RRR blocks for five figures...so those guys with that sort of coin would be interested.
personally unless your after over 1500hp a normal 05U block will do the job. Most of the big hp GTR's in this country are using 05U blocks without an issue. Blocks split and crack due to poor engine harmonics than anything else, an engine prepped and assembled properly with a sensible bore size will not have block issues. The only real advantage of the N1 item is the thicker deck which does in some applications prevent fatigue cracks around the head stud holes when running mega boost.
Edited by DiRTgarage
I would think these blocks would mainly be an advantage for circuit work to get weight from the front. Hence i would like to know the differences in weight of these compared to a normal RB block.
Paul you would know, whats an RB block weigh?
Thoes blocks look like they should be in a show room. I see by their lack of prices these fall into the "if you need to ask" catagory of parts. It would be really neat to see a company like that , that makes engines from raw material make a rb38 or something. I've always thought about how cool it would be if a macinist in his spare time could make a 4L 2 stroke rotax and put it in a car.
I know of a V8 engine for sale, bolt it together for a streetable 1000-2000hp. Basically im saying dont look for anything billet and think you have something special because you dont. Build something factory and get way more respect from the V8 crowd, i got respect from a bloke running a road runner Hemi as his car stock was only 1 second per 1/4 mile quicker than my WRX Which only had 225HP!!
bullet cylinder heads pretty much lead the country for 26 heads, many shops claim to do cnc in house but all they do is send it to them.... :D
one of our heads went back to back with a bullet item on a big car in WA.
i wont say which one was better :thumbsup:
Its the old story of flow data is not everything. part of why i asked about the GTR head allowing 1400hp. I dont like to mention this, but the 2JZ head can flow 2000hp without any porting, whats the maximum power anyone has seen from a GTR with untouched cylinder ports?
Umm what the hell has that got to do with anything?
"More respect from the V8 crowd" What on earth are you dribbiling about?
i wont say which one was better :P
No guessing it was yours that was better Paul, obviously. But , by how much is the real question. I'm guessing i'll get a cryptic answer, but have to ask !
Gary
Do you still use the OEM steel crank girdle or do you get a billet aluminium one too? I would not think there would be much of a weight saving otherwise, and for $11k I would rather grout an 05U block, chuck in some steel sleeves and spend the extra money elsewhere.
edit: Paul, are your heads done by hand or you have a CNC program?
Edited by bigmikespec
do these billet block run coolant systems?
most billet v8 blocks ive seen anr just that...blocks of aluminium with 8 holes in them and a couple of oil galleries.
as for the weight saving, buy a couple of carbon bits like guards and a bonnet and that will be the weight difference, as i hae a feeling that to get it strong enough to hold 1500hp its gonna need to be fairly chunky.
edit: just looked at the website, so they do have cooling passages
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
