Yea that's the problem with these generic kits. You have to go back to supplier to get the replacement stuff.. Hence I normally try and stay away, go for OEM or go for something like brembos.
Try and get back to who you bought them off, and find out if they use the same shape/size as a particular vehicle. I know some AP stuff are taken from specific cars.
yeah pads are an easy replacement - anything to suit the AP racing 6 spot calipers will fit (very common pad size). I bought replacement pads from just jap last time I needed them.
I would also contact Just Jap if I needed replacement discs....but I have not got through a set yet
out of interest, say justjap discontinued these, are there an OEM pad and rotor that match these?
i was under the impression the G4s matched some form of ford pads but have no idea about the rotors. am keen to know as ive heard these are actually an excellent kit for the price.
well like I said pad are available from most reputable brake pad makers for the AP6 piston calipers and they fit straight in. I've always used the just jap/chinese generic pads even for race use with no issues so I would stick with them as long as they are available ($500 for race pads is a good price.....things like pagid can go over $1k a set for these calipers)
for discs you are stuck with the chinese factory....so D2/G4/Ksport retailers. If they disappear you would need new discs/hats/caliper adapters. Having said that I've bought 3 sets of these brakes for different cars and none have shown significant wear or cracks on the discs yet
ive had mine on for about 2months and have considerable hot spots on them already just waiting for the shudder to start then they hit the bin. i was also told ap do rotors also but they'll be expensive as shit and the only ones ive found are a different size only 343mm
can anyone guide me on where i can get replacement rotors and pads for the 8 pistons 356mm g4 kits. that arnt ridiculously priced
We've got QFM A1RM (Ferodo DS2500 equivalent) pads on the shelf to suit the G4/D2 8 piston fronts. $179 for the axle set. If you want a dedicated track pad we can do the QFM Comp 9 for $229 for the axle set, or something from the Project Mu range...
  • 3 months later...
ksport are the same as g4 are the same as d2. the ksport just aren't quite such a lurid colour :(
I'm still running these, on the original (ex-targa) discs from 4 years ago, still going great.
Was looking at this stuff recently. The new K-Sport caliper looks different to the old G4, but the rotors appear to still be the same. Shame that Just Jap dont stock the G4 anymore, in th elast few months they sold them they went for a flat black and were a more attractive kit for the use of the low key colour
yeah sorry I should clarify - the ksport caliper is slightly different because it has different sized leading and trailing pistons, same total piston area. But the pads, mounting brackets, rotors, hats and brake lines are all the same. So just consider them "interchangeable"
Well Tracker, you and Scotsman have proven to me that the G4 were the buys of the century for the money.
If the K-sport are their equal then that is encouraging. I have some of the Endless 6 pots knock offs by KTS which i or a friend will be trying soon. There seems to be far more options for budget brake upgrades these days then there was back around 2005. Back then it was used GTR Brembos or 4.5k for APs/Brembos etc
The real test is finding a good economical rotor in the size you are after.
I still am a brand whore, so much that I just bought another set of big 4 pots, simply because its a brand I have not used before and they may be a better solution then the Alcons :(
Duncan, do you know the cost of the replacement rotor? From just jap?
I called K-Sport a while ago and asked about replacement rotors for there kits (330mm kit).
It was just for the rotor. Would have to re-use the hat.
Front pair where $800. This was around 6 months ago though. Not sure if it still stands.
Cheers
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
    • Nah mate, safe as $800k apartments
