Hi Guys,
I have the below pictured aftermarket R33 rear wing / spoiler for sale.
Obviously it's black, altough the paint isn't in the best condition.
No deep scratches or cracks. No repairs needed, just a re-spray.
I'm not sure what brand it is, a good mate of mine believes it's M-Sport.
It's basically the exact same (or very similar) design to the Series 2 '33 wing, except taller.
Bolts on using standard R33 spoiler bolts/mounts, and some extra little allen key grub screws which I'll keep together for ya.
I'd preffer pick up only at this stage, but if you're interested just message me anyway.
I'm located in Melbourne. I live in St Kilda, and work in Dandenong South so might be able to drop it off depending on where you are.
Make me an offer...!
Buzz me if you have any questions.
Cheers!
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
