2002 Gtr V Spec 2 Nur!
selling my 2002 vspec 2 nur as ive just lost my license for 6 months and by the time i get it back ill be over it lol
white
38000km (approx)
i have the genuine log books but they havnt been stamped much by nissan in japan, but the car was first registered 24/10/2008 with 26,418 km, i bought it with 34,431 km and have put only a few thousand km's around town.
i got it stock with coilovers and nismo front bar, and while owning it ive put the following things on it
- nismo sports resetting ecu (also have standard ecu)
- hks kansai double strut bar
- hks oil cooler kit
- hks intercooler pipe kit
- garade defend GT cooling panel
- tomei fpr
- apexi super suction kit (also have standard airbox)
- apexi n1 3.5" exhaust
- nismo dual 2.5" into single 3.5" front pipe
- nismo side skirts and rear pods
- nismo intank pump
- nismo GT titanium gear knob
- exedy hyper single clutch
- ikeya formula rear camber arms
- bride cuga LIMITED EDITION black seats and rails
VERY CLEAN CAR!
atm it has 18" te37's on it but im keeping them for my race car. most likely come with stock wheels or 19" Rota's.
$70,000 ONO!!!! need to sell ASAP so all SERIOUS offers will be considered and negotiated with. car is actually insured for $75,000 with JUST CAR!!!
0431 961 872
located on the gold coast.
PICS WILL BE UP OVER WEEKEND!
white
38000km (approx)
- tomei fpr
- nismo intank pump
VERY CLEAN CAR!
0431 961 872
PM sent. Do you still have the original seats and all original parts?
hey, na i dont have the original seats or mats, they are bride items.
never had original exhaust, had some aftermarket one on there, i didnt like it
gearknob was also aftermarket so i changed to the nismo GT ti one.
i may have the original rear arms and cooler pipes at work.
ill await ur call :P thx
Can I ask you.. Why you sold for what would be considered Dam cheap??
i think its cause he doesnt want to wait around months and months wasting his time with test pilots and tyre kickers .
like some of the fine examples of GTR's on carsales.com in the 70's and 80thousands that still have sold for ages
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
