Hi peoples,
I got a bit of a curly one for you all!
I just had my car (r33 S2) tuned with a safc2, and althoug i am very happy with the peak output the car achieved, my tuner told me the mid range is being held back a bit becuase of the knock sensors detecting some knock. Obviously the result is timming being pulled out and petrol put in. At about 5500rpm it comes good again and the power curve heads upwards dramatically.
My problem with this is that the tuner told me that it is common for knock sensors to be overly sensitive from factory, as he was unable to detect any knock using his own form of knock detection. I have read threads on how to block out the knock sensors by replacing them with a resitor, or by installing diodes between the ecu and the knock sensors, but am unsure of wether this is a wise move.
Has anyone got any experience with this problem, as i would like to improve my mid range tune without changing computers or anything like that. Any help would be great...
https://www.sau.com.au/forums/topic/306075-knock-sensor-question/
Sounds to me like a poor excuse from a bad tune.
What it would sound like to me on face value is you are still hitting Rich/Retard on the factory ECU even with the S-AFC.
Now, correctly tuned/setup the S-AFC should bend the signal enough to avoid any factory ECU retarding elements.
The factory knock sensors are not over sensitive, you should not be adding restrictors and so on.
If you think he is right, get another one and replace your factory one. I wouldn't be surprised if the exact same thing happened - because of what i said about about poor S-AFC setup.
The factory knock sensors pick up other things besides knock and it registers it as knock, this is why tuners use there own knock sensing equipment, the proper way to fix the issue is a full ecu like a power fc then you wont have these issues.
^ umm the PFC will still pickup the exact same knock level - if the sensor is playing up.
They can pickup a starter motor being loose and banging around for instance.
However putting in a PFC won't magically reduce the sensors sensitivity, or what it reports, so you would still see "danger" on the PFC... IF the knock sensor is acting up.
In which case you would never know if the car is in danger or not...
I still go with what i said initially though, swap out the sensor, if the same thing happens it's the tuner or something unlucky like a loose starter motor.
Very true, i have seen lots of reports of people getting high knock figures but when the tuner is using the after market knock detection there is no or very little knock, replacing the knock sensor( of which i have 2 from a spare engine i bought if you want to try it) may cancel out some of what the factory ecu gets but they are well known for registering a lot more knock than is actually there which will always result in a lower quality tune when only using a piggy back.
The tuner i used is one of the most recomended in my area. His comment on the overley sensitive sensors was a generalisation about the sensitivity of factory sensors. Basically he meant they lean on the side of caution a little too much.
It's sounds like "word3d" has also heard of this, going by what he said about tuners not detecting knock even though the sensors are dectecting something.
Also safc only bends the singnal of the voltage from the air flow meter, so how could that influence R&R kicking in for knock? i know you can stop
R&R kicking in for exceeding the factory set airflow reading, but not for knock!
I never said the 'apparent' knock was related - just that it sounded like an excuse for R&R kicking in as a result of a job not being done 100% right.
As i said, swap out the sensor, you'll soon find out where the issue lies.
I have had a few GTR's and S14's that show high knock figures for no reason, one in particular was a SR20 S14, on the Kmon is was silent, ran a very safe map in it, yet the PFC D-jetro would show up to 50-60 on decel and even at idle would hover around 15-20, at wot it would often hit 95, I went over every squar millimeter of that engine bay, not a single thing loose or contributing. 6 months later I did an engine build for more power, same thing with knock, did not change.
Eventualy I replaced the knock sensor at a regular service and it dropped to about 3-4 at idle and 15 odd on decel with 50-60's at WOT (usualy see 25's to 30's on similar setups) I then replaced the complete knock harness from sensor to ECU, didnt make a difference. I even tried to switch out the PFC's with its sister car running identical setup and still the car im mention would always read close to double,
What I did notice though, if you run a hard core twin plate or tripple plate clutch it can be a very good contributer, SR20's knock sensors usualy go balistic right before/as they chow the teeth off 3rd gear as well. Not saying somthing is wrong with your driveline, just that it could be somthing a little futher down the line thats causing your odd readings.
Good luck, hope you find the problem.
Was this a genuine article or aftermarket. I am presuming that given your circumstances they would be new, not 2nd hand.
Very expensive?
Where from?
Thanks for your replies guys, it is a bit of a grey area i know. Im sure someone else is learning from all this!
people forget that with the SAFC there are always 2 actions for every adjustment.
SO if you get the mixture nice (usually by leaning it out from the factory rich settings) the second action is to the timing table.
Reduce fuel = increse timing
Increase fuel = decrease timing
If you take out too much fuel you generally add too much timing especially around peak torque in the midrange.
Finally if for some reason the car switches over to the low octane map the tuning is done based on the wrong map. A good practice is to run a very aggressive ramp rate once finished then turn the car off for 30seconds and redo the run just to make sure both runs are identical. If it was in the low octane map for the first run the car will most likely knock its head off and be lean on the second run.
I hate SAFC's on anything mildy smart (r34's etc) as it is impossible to get what i consider good results... especially as i monitor the base tables with nistune and see just how average the base figures are to work with.
  • 3 weeks later...
Very expensive?
Where from?
Owned , I just had my knock sensors replaced , problem with sensors was found with a Apexi Fc hand controller , cost is $ 350 per sensor from Nissan not including install - big $$$$$$$, must remove exhaust manifold! The other option is to overide the fault with ECU upgrade .
Edited by NISSAN GTR
Owned , I just had my knock sensors replaced , problem with sensors was found with a Apexi Fc hand controller , cost is $ 350 per sensor from Nissan not including install - big $$$$$$$, The other option is to overide the fault with ECU upgrade .
how silly of me . it is the wrong side Edited by NISSAN GTR
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
    • Good question, I don't really know tbh...I'm pretty stock thought, where could I check this?
    • This. I'm confused by the whole discussion. The only reason you would have a car with e85 only if it was track use and you only ever used e85. All other use cases you add a flex fuel sensor, do the flex tune (you only need to do a couple of % and then interpolate the rest) and then you put whatever the hell you feel like including a mix in the tank and it just works. Want a long drive? fill with 98 Want max zoom? fill with e85 Got a half tank of 98 then find e85 somewhere? Throw it in.
