  • 2 months later...
can I see pics of the front bar so I can make an offer
will drive out to see it.... north of bris
No pics of front bar it is a 400R copy from UAS, it is on the car at the moment, unpainted. PM me your phone no. if you want to check it out
For the people interested in the 400R rear bar + pods here's some pics of mine fitted and painted....
http://skylines.pnc.com.au/pics/ben/bodykit/
The 400R sits about 2 inches lower than the stock rear bar and is much 'fatter'.
Goodluck with the sale 51jay
Yup straight fit. (I have a '95 S1)
take 3 clips out in the middle at the back where it has 'skyline' on ur boot lid part, remove 3 bolts from each end of the rear bar on the inside (thru the boot). Remove your numberplate and light and then it just slides out. You can use all the factory bolts etc to put it back on, just a matter of sanding it back, priming and spraying. An afternoons work.
The pods get bolted into the side of the rear bar and also into the bit on the back of your mud guard.
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
