Hey team,
Ok, Im a little confused...
I read somewhere, someone said you should ALWAYS run the same Wheels and Tyre dimensions on ALL 4 CORNERS of a Stagea... I understand the principals of have 4x drive wheels... Subaru etc. and potentially destroying the drive train.
But...
The Stagea's don't run AWD...? I know of several GTR's that run different sizes front and rear?
Whether it be for example; 18x9 fronts and 19x10 rear....
Im' looking at getting a set of wheels but they're 17x8 and 17x9.
Just need some insight before I do something I regret and eventually devours my wallet.. :D
Cheers,
Aerron
https://www.sau.com.au/forums/topic/306093-quick-stagea-wheel-question/
Mate 17 x 8 and 17 x 9 SHOULD be ok.
Its the rolling diameter that you want to keep the same, width isnt so much an issue. Remembering it will make doing rotations a bit of a pain every 5,000
Hope this helps.
Chris
Hope this helps.
Chris
Ok, So say I was to run 17x8 and 17x9 and wrap them with 235/45's on all 4, even thought the 9's will stretch the 235's slightly, the over all rolling circumference should be very similar.. give or take a little.
Correct?
Correct?
If you put the same tyres on all four wheels the difference in rolling diameter (especially dynamic) could be enough to upset the attessa. Good on you for being the trail blazer. I have seen 350z wheels that i would like but have not bought because front and rear were an inch different. let us know how you get on!
This was my theory to, i thought with the stretch and then the expansion with speed might affect it. Need a giunea cop.
Cheers for the imput guys :thumbsup:
Well to be safe I'll go back to square 1, either R33 GTR wheels or same dimension wheels...
But out of interest, how is that GTRs can pull of stagered fitment... even different diameters?
I guess abit of math... but even then I sat down and you cant get it perfect... :) they're always give or take 5 - 10mm different in circumference. I knew someone who had a 34 GTR had 18x9 front and 19x10.5 rear... regular time attack attender... never broke nor twisted and trive train gear?
:D
ive been running 17x8 fronts and 17x9 rears for ages now
front are 235/45
rears are 245/40 allowing for the stretch to bring the rolling diameter in line
wen i first got my wheels they had shagged 255/40 and the attesa went ape-shit and would badly shake just below 60kmph and then violently at around 105kmph
went to a tyre shop and worked with them to get the right size diameter wise allowing for stretch
got the tyre changed,now all is well
im about to replace the rears,going to swap the front new tyres to the rear and get new fronts so ill be playing this game again soon...
front are 235/45
This is the pain in the arse thing with the attessa system. Even with my stock stagea rims when I first got the car I got new tyres for the front and put the old fronts on the back (as you would normally do), however this caused the attessa system to do the same thing as you mentioned. So I eneded up getting them to put the new ones on the back and the old ones back to the front. Was fine then, so even the tread height difference between new and old tyres of the same size is enough to cause it to have a fit. So now I just get four new tyres, keep rotating them to get as much life out of all four as possible then replace all four again. But I really want to get some descent wheel soon (once suspension is sorted out) and would love to get wider wheels at the back but I'm not going to as I its going to stuff up the way I rotate wheels. So I'm thinking just 33 or 34 wheels.
I have been running 17x8 front 17x9 rear with 235/45 all round for a couple of years now with no problems as far as the attessa system goes. I have had it on Queensland raceway in this form also with no problems. When it comes time to do a rotation it’s a case of a strip and refit.
    • I have multiple bottles in a shed that gets hot, and I'm in SEQ, so it's humid. Maybe we test their theory... Anyone have a system to accurately measure moisture content in oil?
    • Yeah, that and throwing away opened, part used, closed back up bottles has got to be bullshit. Brake fluid sits in not-very-well sealed master cylinder reservoirs for literal years and keeps working (albeit we know we should flush it every couple of years - it actually still works). Anything kept in a bottle in the shed with a tightly capped lid has got to be a million times better than what has been in the car for the same length of time.
    • Wait, they're claiming UNOPENED fluid has a shelf life of only 18 months?
    • The plan is to get it out of the shed. The reality may fall some way short. But hope is as cheap as despair as they say. Will go a wide band I think. The coils are ok so maybe I’ll miss the $1500 on the R35 coils etc. Im still on the fence about a trigger kit. The HKS one looks nice ($1k) - not sure how it works with the Link or if Link prefer something else. Oil pressure is fine so I’m not that concerned there. Fuel pressure I’ll have a think about. The IAT got changed for the Link anyway as the old RB26 ones were really slow reacting and pretty poor. The Power FC just worked. Wasn’t terribly refined but it just worked. Probably made a mistake replacing it really. E85 isn’t available locally - it is 100+ kms away which puts it in the too hard basket. Lastly I understand Tunecorp in Perth are pretty good so was probably going there.   As for turbos is there are new age -5 drop in replacement? Turbos have come a long way in 20 years, everyone is big single which is fair enough but I prefer the old school complication of twins. Wasn’t chasing more power (well, not much more) but more efficiency would be ok.
    • I thought I'd share this....the shell is non genuine but they found or built a lot of the genuine parts. Plus, it is by far the best colour scheme of those years, the winfield once was particularly shit https://www.v8sleuth.com.au/written-off-inaugural-godzilla-recreated/
