I've been considering getting the HID R33 headlights, but they go for a pretty penny here in Japan. found some new in the box for 1600 USD. not worth it at all. that's my Tomei Oil Pump, or something else useable.
Since I'm typing- updates today. Replaced starter, old one said goodbye over the weekend filming that video. That is the most pain in the ass starter I've ever had to replace, took me over 2 hours of pleading with god to get the top bolt off. Also removed the sound deadening that was cemented to the floor pans and such. On the prowl for a roll cage, interior sprucing up after that.
pffft wow! no shit that looks tuff with the new wheels 30profile thats brave ahah, love that last photo too!
Thanks mate. These are probably going to be my cruising wheel/tire combo, as it's a terrible set up for the track. probably will opt for the more standard 18"/35 series on the track.
Oh.... that last photo made me all tingly inside (DOF shot)... Hires plz? :)
here ya go, it's 28 megapixels though.
also, completely removed the sound deadening that is cemented to the floor panels. Use a pneumatic chisel and bulldozed it in just over an hour. Screw the fancy dry ice shit. haha, this way cost me free 99. And to celebrate here's a weight update.
Weight update...
Removed rear seat and rear seat safety belts for 31 pound/14.1kg reduction.
Stock Trunk Carpeting - 11.5lbs/5.2kg
Stock Floor Mats - 13.0lbs/5.9kg!!
Stock Jack/Tire Iron - 4.5lbs/2.05kg
Stock Spare Tire - 34.4LBSSSS/15.6kg
Nissan Air Purifier,sound deadening behind back seat, car jack - 9 lbs/4.1kg
metal plate behind the back seat - 6.4 pounds/2.9kg
Stock suspension 57.8lbs/26.3kg and HKS Hipermax 47.0/32.3kg - 10.8lbs/6kg net loss
door panels 14lbs/6.35kg
carpet and various pieces of plastic 16.2/7.3kg
Center console 7.6lbs/3.5kg
passenger seat 34lbs/15.4kg (with rail attached)
Difference in test pipe/cat 6lbs/2.7kg
new seat/rail vs old seat/rail 5lbs/2.3kg
dash stripped to shell - 3lbs/1.36kg
difference in exhausts 24.2lbs/11kg
all sound deadening 12lbs/5.5kg
242.6 pounds/110.3kgs
Stock R33 GT-R 3388lbs/1540kg
so I'm at 3145.4lbs/1429.7kgs. Still heavy! Still to come out. Rear windshield wiper assembly, HICAS, switch to CF Driveshaft, stock exaust manis, outlet pipes and downpipes.. to be replaced with SS and titanium respectively, and more!
Ive been going through this thread and im frickin loving the work mate,thats real talent.It'l be the ultimate test for a permanent marker lol
Just imagine if it was in fluoro sharpie haha thatd be sick.
rb30 huh? OS Giken sells an rb315 kit to up your 26 displacement to 3.15L
http://www.osgiken.co.jp/pro_spec/rb30kit.html
Nice work btw; love this thread.
sounds cool, but for almost 20,000 USD, I can buy an insane engine already done up vice the OS Giken stroker kit :D
I'd like to thank Fast Car Magazine! Maybe when the car is done, they will be interested in a bigger spread!
Build is on hiatus until after I purchase Allison an engagement ring. Shhhhhh!
polished the headlights, and removed the A/C radiator/fan. compressor is next but i didnt go to the garage today.
the radiator and fan weighed 15lbs/6.8kgs
Weight update...
radiator and fan 15lbs/6.8kgs
249.4 pounds/117.1kgs
Lost Birds R33 3130.4lbs/1422.9kgs.
Edited by istdercollen
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
