I've been considering getting the HID R33 headlights, but they go for a pretty penny here in Japan. found some new in the box for 1600 USD. not worth it at all. that's my Tomei Oil Pump, or something else useable.
Since I'm typing- updates today. Replaced starter, old one said goodbye over the weekend filming that video. That is the most pain in the ass starter I've ever had to replace, took me over 2 hours of pleading with god to get the top bolt off. Also removed the sound deadening that was cemented to the floor pans and such. On the prowl for a roll cage, interior sprucing up after that.
pffft wow! no shit that looks tuff with the new wheels 30profile thats brave ahah, love that last photo too!
Thanks mate. These are probably going to be my cruising wheel/tire combo, as it's a terrible set up for the track. probably will opt for the more standard 18"/35 series on the track.
Oh.... that last photo made me all tingly inside (DOF shot)... Hires plz? :)
here ya go, it's 28 megapixels though.
also, completely removed the sound deadening that is cemented to the floor panels. Use a pneumatic chisel and bulldozed it in just over an hour. Screw the fancy dry ice shit. haha, this way cost me free 99. And to celebrate here's a weight update.
Weight update...
Removed rear seat and rear seat safety belts for 31 pound/14.1kg reduction.
Stock Trunk Carpeting - 11.5lbs/5.2kg
Stock Floor Mats - 13.0lbs/5.9kg!!
Stock Jack/Tire Iron - 4.5lbs/2.05kg
Stock Spare Tire - 34.4LBSSSS/15.6kg
Nissan Air Purifier,sound deadening behind back seat, car jack - 9 lbs/4.1kg
metal plate behind the back seat - 6.4 pounds/2.9kg
Stock suspension 57.8lbs/26.3kg and HKS Hipermax 47.0/32.3kg - 10.8lbs/6kg net loss
door panels 14lbs/6.35kg
carpet and various pieces of plastic 16.2/7.3kg
Center console 7.6lbs/3.5kg
passenger seat 34lbs/15.4kg (with rail attached)
Difference in test pipe/cat 6lbs/2.7kg
new seat/rail vs old seat/rail 5lbs/2.3kg
dash stripped to shell - 3lbs/1.36kg
difference in exhausts 24.2lbs/11kg
all sound deadening 12lbs/5.5kg
242.6 pounds/110.3kgs
Stock R33 GT-R 3388lbs/1540kg
so I'm at 3145.4lbs/1429.7kgs. Still heavy! Still to come out. Rear windshield wiper assembly, HICAS, switch to CF Driveshaft, stock exaust manis, outlet pipes and downpipes.. to be replaced with SS and titanium respectively, and more!
Ive been going through this thread and im frickin loving the work mate,thats real talent.It'l be the ultimate test for a permanent marker lol
Just imagine if it was in fluoro sharpie haha thatd be sick.
rb30 huh? OS Giken sells an rb315 kit to up your 26 displacement to 3.15L
http://www.osgiken.co.jp/pro_spec/rb30kit.html
Nice work btw; love this thread.
sounds cool, but for almost 20,000 USD, I can buy an insane engine already done up vice the OS Giken stroker kit :D
I'd like to thank Fast Car Magazine! Maybe when the car is done, they will be interested in a bigger spread!
Build is on hiatus until after I purchase Allison an engagement ring. Shhhhhh!
polished the headlights, and removed the A/C radiator/fan. compressor is next but i didnt go to the garage today.
the radiator and fan weighed 15lbs/6.8kgs
Weight update...
radiator and fan 15lbs/6.8kgs
249.4 pounds/117.1kgs
Lost Birds R33 3130.4lbs/1422.9kgs.
Edited by istdercollen
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
