R32 Stock Shocks
i want to lower my r32 4door and it has stock standard shocks, can i lower them from the top of the shock or would i need to get lower springs for them? or the cheap option of chopping them? i noticed 2 nuts on the top of the shocks so im guessing u might be able to lower them that way, please let me know
The springs support the weight of the car. The shock absorbers control the motion of the springs. You can only lower the car by fitting low springs.
I happen to have a set of stock springs that have been reset to lower the ride height, if you are interested.
You can actually shorten shocks..
But its not really ideal for stockers. I think the Tein "dress up master" springs are great. Retain a relatively stock feel to them harshness wise, but are a little firmer.
Lowered my GTSt around 30-35mm
Gives it a nicer look, yet retains the ability to clear pretty much all speedbumps/driveways. Unless your 3/4 up :s
This was immediately after putting it back together, so the springs hadn't quite seated into the rubber bits yet.
Edited by gotRICE?
I have standard 32 suspension too and wondering if its worth it to buy lowerd springs for the standard setup or just save n buy some coilovers? say 300 bucks for some springs or fork out 1000+ for a decent set of coilovers... mm winning lotto would be good :action-smiley-069:
+1 for the TEIN springs.
I would advice against touching the shocks. You 'can' chop the springs if you want but not sure of the ride quality afterwards, if you do be careful how much you take off! For $300 I would just by some lowered springs. If you look around you could probably find some second hand ones for a bit less.
it depends what you use the car for.
lowering springs such as king springs/pedders/teins fitted to standard shocks can prove to be a great upgrade over standard. keep in mind that these springs are lowered to suit the stroke of the standard shock, to ensure you are not hitting the bump stops.
makita-spec springs are terrible, unless you like the car bouncing around like a pogo stick.
aftermarket coilovers are great for adjustability and are a good option for not just lowering, but provide proper handling (depending on what sort of adjustments there are). if you plan on slamming the car, make sure you get body height adjustable coilovers.
  • 4 weeks later...
 Share
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
