R32 Stock Shocks
i want to lower my r32 4door and it has stock standard shocks, can i lower them from the top of the shock or would i need to get lower springs for them? or the cheap option of chopping them? i noticed 2 nuts on the top of the shocks so im guessing u might be able to lower them that way, please let me know
The springs support the weight of the car. The shock absorbers control the motion of the springs. You can only lower the car by fitting low springs.
I happen to have a set of stock springs that have been reset to lower the ride height, if you are interested.
You can actually shorten shocks..
But its not really ideal for stockers. I think the Tein "dress up master" springs are great. Retain a relatively stock feel to them harshness wise, but are a little firmer.
Lowered my GTSt around 30-35mm
Gives it a nicer look, yet retains the ability to clear pretty much all speedbumps/driveways. Unless your 3/4 up :s
This was immediately after putting it back together, so the springs hadn't quite seated into the rubber bits yet.
Edited by gotRICE?
I have standard 32 suspension too and wondering if its worth it to buy lowerd springs for the standard setup or just save n buy some coilovers? say 300 bucks for some springs or fork out 1000+ for a decent set of coilovers... mm winning lotto would be good :action-smiley-069:
+1 for the TEIN springs.
I would advice against touching the shocks. You 'can' chop the springs if you want but not sure of the ride quality afterwards, if you do be careful how much you take off! For $300 I would just by some lowered springs. If you look around you could probably find some second hand ones for a bit less.
it depends what you use the car for.
lowering springs such as king springs/pedders/teins fitted to standard shocks can prove to be a great upgrade over standard. keep in mind that these springs are lowered to suit the stroke of the standard shock, to ensure you are not hitting the bump stops.
makita-spec springs are terrible, unless you like the car bouncing around like a pogo stick.
aftermarket coilovers are great for adjustability and are a good option for not just lowering, but provide proper handling (depending on what sort of adjustments there are). if you plan on slamming the car, make sure you get body height adjustable coilovers.
  • 4 weeks later...
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
