Hey guys and girls,
I have recently converted my R34 Gt sedan from an RB20DE to an RB25DET Neo from a GTT and converted it to manual. We have kept my standard r34 de afm which we believe is the problem.
We have started the car and it drives like a dream untill you plant foot and it starts to boost.. Basically we have worked the actuator hoses to run a constant 8 PSI which is standard of the actuator? am I correct? Which is cool but when we try to boost it boosts up to and sticks at 5 PSI for about a 1000 rpm then it cuts out. We have connected this to a diagnostic tool and at the exact second that it cuts out the injector cycle dies and gives an afm voltage of approx 4.7V Which is right on the verge of maxing out....Please feel free to correct me if I am wrong...
Im just wondering would the afm maxing out cause the ecu to cut the injectors and cause it to only run 5 PSI?
Can someone who has an R34 GTT with an 25DET in it please inform me as to the colour and numbers located on the AFM. I believe they are pink but the numbers may be diffrent.
Or is there another issue causing this that we may have overlooked....
Any help would be greatly appreciated.
Cheers,
https://www.sau.com.au/forums/topic/306209-r34-injector-cut-afm-issue/
Neo AFM part number will either be 22680-31U00 or 22680-31U05. i'm sure all Neo's weather being turbo or N/A will use the same AFM, i have checked this in FAST before.
You should check what Trent said, the stock Boost Sensor. It will detect an overboost and cut the engine they way you describe, or if it isn't hooked up will through an error code on the ecu. i haven't tried it but this error code may cause the ecu to run in a safe mode and cutting the engine before you load it up too much. and having done a conversion, it could be something that was overlooked?
My AFM is 22680-31U00 like you said... and Im pretty sure the sensor has been connected but it wont even boost to 8 PSI like it should do??? It goes to 5 PSI on the dot and wont move past even after sitting there for 1000 - 1500 rpm before it cuts out completely...so could it still be the sensor? would that not mean it would cut out above say 12 PSI where it would normally go to 8 PSI with ease
Cheers
yes, if the boost sensor is connected you will hit a cut at about 14psi. one thing, i have a RB25 NEO in my Stagea. on the Stagea the standard wastegate is 5psi, with a stock boost solenoid bleeding off to 7psi once you hit about 3500rpm (i cant remember the exact point). I think the R34 is the same, someone will correct me if i'm wrong though lol. Have you used some kind of boost control to get 8psi?
Edited by QWK32
I am not the one putting the motor in but i just had a bit of a look around it and it is actually an RB25DET NEO out or an C34 Stagea...So that makes sense only getting to 5 PSI. I was told they were 8 but i guess not. The loom has been re wired to accomodate my motor and my afm only has three wires and yours has 4...Is that my problem then...Do I have the wrong afm?
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
