  • Replies 177
Posted Images
not all true......loved the 35 and also the silver 33 gtr, all the imports for that matter, except the fat toyota lol.......but the Camaro could just bag em up for fun.
stu you are showing a very strong v8 bias...do you like them or something??
some shots i got under ians tution, note this was my first lesson.
there are more but take too long to upload.
If you've got Photoshop resize them to 800 x 600 pixels and they'll be much quicker. :P
Come on! There had to be more video footage then what has been posted.
All I heard after I ripped a massive skid was that heaps of people had it on video... So where is it all?
Ben... Scour your Camaro friends to see if they had footage?
Yo folks - (ashamed and hides under rock)
I've got a number of vids but work has kept me locked in a very dark room where they slide a meal to me through a slot under the door.
Seriously, I've just got to do some more clipping and planning on u/l to SAU Youtube channel. I'll try to get a couple of teasers up soon.
Sorry Matt no vids of your big skidz.
ok videos are going up. Having issues with Kaspersky and youtube so it is slow going. I'll try to do a couple of videos every couple of days. These are the ones from the early session 1, I've also got slow motion playing in the rain and afternoon battles coming soon.
Dam! Turismo makes it look way too easy! Guy's got skills.
enjoy: Texi!!!
Oh, and I'm now posting these on the NSWSAU YouTube Account. Subscribe so that you get updates emailed to you.
It's alright Eric, I already knew you didn't like my skids :)
I'm going to try and chase Owen as I thought he had some video too.
Ben, would be awesome if your mates got some of my skid videos. And if they didn't vids of other peoples skids is nearly as good for me!
here is me destroying whats left of my tyres after the texi.. Ill have to look Matt to see if there is any vid of your big skid..
That'd be awesome Dave if you could.
Nice vid too!
I'd have been out there too if I hadn't found a motor problem... LOL
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
