Texi - Skids On Sunday - Teh Aftermath!
evil_weevil
 Share
  • Replies 177
Posted Images
not all true......loved the 35 and also the silver 33 gtr, all the imports for that matter, except the fat toyota lol.......but the Camaro could just bag em up for fun.
stu you are showing a very strong v8 bias...do you like them or something??
some shots i got under ians tution, note this was my first lesson.
there are more but take too long to upload.
If you've got Photoshop resize them to 800 x 600 pixels and they'll be much quicker. :P
Come on! There had to be more video footage then what has been posted.
All I heard after I ripped a massive skid was that heaps of people had it on video... So where is it all?
Ben... Scour your Camaro friends to see if they had footage?
Yo folks - (ashamed and hides under rock)
I've got a number of vids but work has kept me locked in a very dark room where they slide a meal to me through a slot under the door.
Seriously, I've just got to do some more clipping and planning on u/l to SAU Youtube channel. I'll try to get a couple of teasers up soon.
Sorry Matt no vids of your big skidz.
ok videos are going up. Having issues with Kaspersky and youtube so it is slow going. I'll try to do a couple of videos every couple of days. These are the ones from the early session 1, I've also got slow motion playing in the rain and afternoon battles coming soon.
Dam! Turismo makes it look way too easy! Guy's got skills.
enjoy: Texi!!!
Oh, and I'm now posting these on the NSWSAU YouTube Account. Subscribe so that you get updates emailed to you.
It's alright Eric, I already knew you didn't like my skids :)
I'm going to try and chase Owen as I thought he had some video too.
Ben, would be awesome if your mates got some of my skid videos. And if they didn't vids of other peoples skids is nearly as good for me!
About 25mins of video but only of the camaro's.
Damnnit... :)
After my first big skid everyone was walking around going "We all have it on video"
Well where'd it go people!
here is me destroying whats left of my tyres after the texi.. Ill have to look Matt to see if there is any vid of your big skid..
That'd be awesome Dave if you could.
Nice vid too!
I'd have been out there too if I hadn't found a motor problem... LOL
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
