installed 044 car started and drove ok but under power seems to be starving and would'nt rev out, i did use std sock off old pump,any help appreciated.
You might want to change the sock to a new one or maybe none at all its probably restricting it as it would not be able to supply the 044 with enough fuel.
thanks for the help, got it sorted,it was a install problem, i didn't slide the cradle far enough back on the rails so it moved and was laying on it's side so i guess there was a kink in the feed line, the joys of DIY, at least i know a bit more about internal pumps.
