Hey all got a heap of bits hanging around....
R33 Gtst(I've kept engine gbox and loom)
interior bits(front only) ie kick panels, glove box etc
Front suspension
Front hubs and knuckles
sway bar
crossmember & engine mounts
passenger airbag & module
Dash/crash pad
Radiator w/shroud
full air con setup all bits
.... heaps more just ask and I can let you know if I have
32GTR
Abs unit
condenser fan
Left and Right mirrors complete
Cusco offset number plate mount(may fit others/brand new)
Trust Jasma cat back exhaust
Gauge holder a pillar twin gauges
Centre console(average cond)
Cluster surround facia(some switches remain)
window switches in doors
door handles exterior & interior
S13/180sx
Full 4 stud everything brakes etc
crossmember
steering rack
gearbox with either ca18 or sr20 bell housing(have both)
ca18 front mount pipework
ca18 alternator(painted gay blue)
ca18 clutch xtreme(no more details know)
180sx front bar fibre glass unknown brand/make(cheap cheap need it gone)
Random bits
Venom boost Gauge with a pillar holder
Tein EDFC unit with all motors and wiring
Isotta white evo steering wheel & matching gear knob
180sx full boot & rear window
Basically throw me offers for what you want/need, need all the space back. R33 half cut prob has a heap of bits I didn't mention
so just ask, Ive kept all running gear though and wiring.
Cheers
Jason
0413 247 219 or pm me
Edited by Jason is me
  DMIN8R said:
any pics of how that cusco offset number plate mount sits with plates? how much for it?
not my link but what it looks like
http://images.google.com/imgres?imgurl=htt...sa%3DN%26um%3D1
goes in front of gtr bov location, google it for more pics. $70
  GTReality said:
Do you have the clutch booster for the R32 gtr?
Sorry no, do have an abs unit though
Jason
  TerryL said:
how much for this?
Make an offer that your willing to pay. Please be realistic though.
As with all parts Guys, make an offer need it all gone.
Front suspension $80
Front hubs and knuckles $100 pair
upper control arms $50
sway bar $80
crossmember & engine mounts $100
passenger airbag $100
air bag module $100
Dash/crash pad $100
Radiator w/shroud $100
full air con setup all bits $150
Tow arms(standard) $60 pair
washer bottle $25
32GTR
Abs unit $60
condenser fan $don't care
Left and Right mirrors complete $50 each
Cusco offset number plate mount(may fit others/brand new) $70
Trust Jasma cat back exhaust $300
Gauge holder a pillar twin gauges $60
Centre console(average cond)$15
Cluster surround facia(some switches remain) $25
window switches in doors $120
door handles exterior $30 each
door handles interior $15 each
S13/180sx
Full 4 stud everything brakes etc all together $400 will seperate pm for bits req
crossmember $60
steering rack $50
ca18 front mount pipework $100
ca18 alternator(painted gay blue) $50
ca18 clutch xtreme(no more details know) $60
180sx front bar fibre glass unknown brand/make(cheap cheap need it gone) $100
Random bits
Venom boost Gauge with a pillar holder $50
Tein EDFC unit with all motors and wiring $300 ono
Isotta white evo steering wheel & matching gear knob $120
180sx full boot & rear window $100
Cheers
Jason
  Weezy said:
What condition is the cluster surround in? Can you please get me a picture. Cheers.
I think its in average condition, if your after a mint one I'd keep looking.
I'll grab it out tonight, if its in good nick I'll post up a pick.
Cheers
jason
  talky said:
hey mate ...got the passenger side air vent by any chance???
If your talking R33, then yes. r32 no.
was intending on selling with whole dash.
Make offers people, I need all this stuff gone!!
  blind_elk said:
Have you got the plastic bits that go around the steering column (r32)?
No i don't have that piece sorry.
Jason
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
