Hi all,
It is pretty simple really i have a r32 gtr with 2xhks 3037 and i was wondering what is the best boost controller to use.
Currently running 24psi for street and i don't know what i'll use for the drag yet but it has to hold alot of pressure
Recommendations and comments please guys
https://www.sau.com.au/forums/topic/306237-best-boost-controller/
So get heavier springs? 10psi is a lot to be bleeding off etc.
I'd be surprised if you are not seeing a bit of gate creep with that.
the reason i want to change to a boost controller is that i am currently running boost control through my haltech and the control dial is just sheeet to set. so i want to know what controller people recommend keeping mind that i two waste gates. the boost was set to 1.7 but when i was working on the car i found a hole in a hot pipe from the rear turbo i have since fix this and now its over boosting to 1.9-2.0 so i have disconnect the haltech boost control and just using the wastegate springs for now to control boost
i'm a big fan of profec b II for good boost control, a lot of ebc's dont seam to give you the option of when to start pulsing the solenoid which is important for stopping gate creep. heavier springs closer to your target boost is always a good idea tho
personally i dont think the profec or blitz are up to the challenge of 2 x 3037 but i totally agree with STATUS, the HKS has no hope.. dont get me started on HKS
seeing as 2 x 3037 isnt exactly backyard hiflow material, dont go cheap on the controller. i believe turbosmart make an EBOOST 2 capable of 60psi? have seen one run an evo with its 15yo 8 psi actuator at 27psi flat to redline. thats saying something.
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
