Hello All in the N/A world
Im looking for some views / advise on this particular part
Is it worth having this kit put into the car if im not planning to drive track ?
http://www.efihardware.com/products/724/6-...COE-economy-kit < Follow link
Is it worth just having a uni filter kit to standard t/b or will this part work well with the engine
if my only other plans are exhaust and ECU ?
Thanks to all
Edited by simjim89
https://www.sau.com.au/forums/topic/306254-rb25de-r34-single-throttle-body-kit/
well to begin with
the kit you have the link to is not a single throttle body kit
it is a 6 individual throttle body kit
you will not need the one throttle body that the 34 as the moment as it will be replaced by the 6 ITB's....
you will also be needing a custom manifold as well as bigger injectors, and you have already said you would be getting an aftermarket ecu?
if you want to keep your car legal it would be worth while getting the car engineered certified if you go ahead with it all...
well to begin with
Thanks For the info ..... i will look into this.....
