I've had my car for a few weeks now and I noticed that every now and then the revs will fluctuate when sitting at idle and usually when slowing down the revs dip really low and sometimes the car will stall.
I've done some research and found lots of information on faulty PCV causing the dipping revs but nothing relating it to the fluctuation.
I mentioned it to my mechanic and he said the car might just need a good run and may have picked up some bad fuel. Now 800kms later it still does it from time to time and it is driving me crazy.
The car is going to the mechanic on Tuesday to get the problem sorted and I wanted to give him an idea of what the problem could be. The car is a 1996 Skyline R33 GTS-T series 2 with 75,000kms on the clock.
Any help would be greatly appreciated.
Dylan.
https://www.sau.com.au/forums/topic/306256-fluctuating-and-dipping-rpm/
you might have already found this during your research, but a common problem for the idle issues is caused by a faulty/dirty AAC valve...there is also a DIY on how to clean it yourself.
I have similar idle issues but mine is ecu related due to an rb20 remap...
good luck!
Frankly, I don't understand what all the fuss is about erratic idle. It's only idle, FFS. If it were doing it in the middle of an overtaking acceleration, then, yes, you have a right to be concerned, but it's just at idle.
As for the stalling, service the AAC (will probably solve the disaster that is your erratic idle as well).
I have a similar issue with my car. It running a Haltech E11v2, Nismo 740cc Injectors, and when the aircon is on and i am slowing down to stop at the lights, it always stalls. Another thing it does is it rev hunts when idling at the lights sometimes (generally on warm days), but other times it can be fine.
What do you reckon? AAC Valve too?
does your AAC connected to your haltech? my friend here also uses haltech, but for AAC he says haltech needs additional controller to control AAC valve opening. Currently his aac valve isn't connected, and having same symptom like you. And also it stalls while parking (maneuvering/driving in slow speed).
Basic function of AAC valve is to increase RPM when there's additional load like aircon and power steering, otherwise it would stall.
Or just try to do simple fix by cleaning your AAC valve, works well on my rb20det, no more stalling issues
I'm fussed because it sounds annoying and can't be good for the fuel consumption, I want my car to be running top notch :D
Seems like everyone has a idling related problem.
Sorry for hijacking, I have a idling problem that seems to be related to surrounding temperature.
When I drive around during the day (outside temp is ~30+C) the base idling rpm is ~740 to 750, but when I drive around at night (outside temp would be low to mid 20C) the base idle rpm drops to around 680 to 700rpm?
At this dropped idle rpm you can feel a slight vibration from the steering wheel while stopped at the lights.
Any idea on why temperature is causing the drop in idle rpm? Still AAC valve related?
Car has basic mods. turbo back exhaust, POD, R34 GTT SMIC, bleed valve (up to 10psi), SAFC 2 & stock BOV.
Thanks.
Edited by Mayuri Krab
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
