I'm going to purchase a V35 Skyline Coupe in the new year sometime, and I just wanted to know what SAU thought of it?
I realize you guys probably haven't seen one in the flesh, let alone drive one, but what do you think of it overall? A step in the right direction?
I used to loathe this car, but since I made a few contacts in the car auction industry here (therefore opening up oportunities to seriously consider a V35), I really had good look at them, even having a ride in one yesterday. I didn't drive it myself (but thats cool because it was an AT anyway...) but from the passenger seat I could really see what Nissan are trying to do with the Skyline now... High Performance All-round GT perfection!!! Seriously, the ride, handling, seamless acceleration, and the fit/finish of the car is nothing short of awesome. It felt like a "big" coupe, but not in a bad way like some people say of the R33.
The V35 is quality all the way. The guy who was driving took it to redline once or twice, and only stomped on the brakes once, but from that I can only conclude that this car is like the R34s GT-Ts big brother. Seriously.
I WANT TO MODIFY ONE.
  • Replies 100
i like the rear design but not the front.. otherwise the interior looks nice
I think it'll grow on you RedLine... just give it time...
its definately looks like a 350z side on, a Bluebird front on, and rear? kinda looks like that old r35 prototype pictures they released
i dont like it, but its not bad either
Not a worthy successor to the R34 if you ask me
2007 people.
That black one slammed on the Te37's isn't bad.
I think Nissan are stuck between a rock and a hard place.
Renault and this move towards N/A cars with their rounded styling isn't exactly to my liking.
I think the family resemblance thing is going too far. It's too bad a leap for me really.
You can sorta see the progression from 32-33-34 but just like how the 32 was something quantum over the 31 maybe given time, we'll see the 35 in the same way.
Just not right now in 2003!
T.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
