Hey kids,
Was at the track and revving 2nd a bit and went to put it fast into 3rd and heard a big crunch followed by it seeming in neutral. Took it out of 3rd n back in and again was like neutral. I got all my others gears just lost 3rd and im left with a bit of pop corn sounding noises while I nursed it back.
who knows there gear box’s?
What models are interchangeable and is it only gtr box’s I can use? I doubt ill put something else in but just food for thought.
Mines a 91 R32 GTR so it’s a push clutch setup.
am i better off getting another 2nd hand box or rebuilding? the snycros were also a lil worn in my box and gave the odd crunch down changing into 4th now and then but other than that it was pretty good.
Edited by Inline 6
https://www.sau.com.au/forums/topic/306274-broken-gear-box/
  • Replies 59
Posted Images
You have the same gbox as me
I'll sell u my gearset + synchros once Ive fitted the 33 gtr s2 box ;P (if u want it)
-D
Hey kids,
who knows there gear box's?
What models are interchangeable and is it only gtr box's I can use? I doubt ill put something else in but just food for thought.
Mines a 91 R32 GTR so it's a push clutch setup.
https://www.sau.com.au/forums/topic/306274-broken-gear-box/#findComment-5063742
You can use 33GTR box's you just need to turn the slave cylinder around and also swap another part where the input shaft is. I had a 33GTR box in my car but blew the transfer case so put the 32 box back in.
https://www.sau.com.au/forums/topic/306274-broken-gear-box/#findComment-5063750
For some reason my browser is acting wiggy, I deleted my win7 beta installation and installed win7 ultimate final retail, and for some reason the version of firefox i'm using wont let me do what i want to do... and tbh im still installing software so i think its something ill look at later...its annoying the hell out of me tho
-D
could get a 25 box there stronger than 32's and don't have the 3rd gear failure that plagued the 32
EDIT
Ben - why are you now quoting people below your response
https://www.sau.com.au/forums/topic/306274-broken-gear-box/#findComment-5063766
granny shifting not double clutchin' like ya should be :)
lol Vu, you don't double clutch (it's not a truck with a crash box), you flat change if you can trust your synchros and gear selectors.......I wouldn't on a 5 speed GTR box though :):no:
https://www.sau.com.au/forums/topic/306274-broken-gear-box/#findComment-5063772
really Chad
there is basically only a couple of gearboxes nissan built RB20, RB25push RB25Pull seen in late model 32 and all 33 GTR's some late model s2 33's might have the pull type gear box too
If you said 25GTS4 box it would have made more sense.
https://www.sau.com.au/forums/topic/306274-broken-gear-box/#findComment-5063785
Os Giken kits are also very good, strong gears at a more racing biased ratio
That's what I'd get if I blew the 33 gtr box...
-D
i've seen 2nd hand GTR boxes going for $600-$1500 second hand.
to rebuild a gearbox with nissan parts is around the $4k mark
or go PPG for around $6-10K (like i did)
my 2 cents.
Nigel.
https://www.sau.com.au/forums/topic/306274-broken-gear-box/#findComment-5063832
cheers nigel, was the 6-10k with labour to fix it? i reckon i can get a few boys to help me rip it out n put it in so hopefully thatll save me a little bit :)
https://www.sau.com.au/forums/topic/306274-broken-gear-box/#findComment-5063842
Dan - just got off the phone to Shaun at boostworx to see 2 things that my advice of any gearbox will be able to be mated in albeit a rebuild of input shafts and 2 could he rebuild your and that he can your looking at just $1000-1200 just to get the box in and out and labour while its out plus parts :action-smiley-069: not too bad give him a ring if you want any advice
https://www.sau.com.au/forums/topic/306274-broken-gear-box/#findComment-5064236
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
