BIT-SUS, whats the PPG gearset like to drive with?
AWESOME.
- Helical synchro, sounds like an F1 car!
not as loud as a straight cut (WHERE'S THAT REX??)
But brilliant. I'm loving the new ratios (1st=90km/h)
Been smashing through the gears for ages now with the Exedy Carbon twin plate,
would highly recommend PPG gearbox. my total bill came in at $9,800 for parts and labour at PPG, and about $900 to R&R gearbox with a new clutch
I went for the
1-5th Helical Synchro kit
Billet selector forks
Billet input shaft
new synchros
new bearings
new seals
4L of Redline Lightweight Shockproof
never looked back.
  • Replies 59
Posted Images
GTR gearboxes are strong - its high rev gear changes in the lightning quick fashion that kills the syncro which just can't keep up then the gear faces strip with bits of syncro floating around like boat people north of Australia. Mechanical Sympathy is the cheapest way to keep gearboxes together, the tenth of a second you change gears faster by as you reef the gearstick through its gates makes no appreciable difference to your ability to eat other car makes - on a closed circuit of course :P
That being said the gear ratios and clutchless shifting (talking dogbox) are superior for track work :)
well the clutch is going in next weekend hopefully...getting my thrust bearings and other stuff tomorrow or friday....also getting the diff done at the same time so should be reasonably good
Typically a clutch is all those brass button can be cushioned with ceramic clutch pads unless you've gone for a carbon one
i wanted to know what type and what plate face and compound he went for, as in single plate, multi pate, full face, puk, organic,brass, ceramic, carbon etc..
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
