mate u dont have to cop the fine or suspension.
remember how i got a fine for apparently doing 130 in a 80 zone nearly 1 year ago??? I still got my license and fighting the chargers and still have my license.
The courts and law can be your friend even if the cops and government aint :D
Not everyone is going to fork out big $$$ more than what the fine is worth...
Just to keep thier license... and a lawyers Merc repayments up.
And note... you STILL fighting, basically all your doing is putting it off.
Tell me what happens AFTER the day in court and then we'll see :headspin:
And howe much the final bill is for the whole thing.
Me, fought it on me own... and took it in the ass, lost the license, and now just about got it back.
I'm all over and done with and your not even finished...
so NER, now we both even in the stirring stakes :upurs:
but unfortuantely it will prob still b on ya record
unless u change ur name or somethin
Yeah, i'll change my name from
Denham the guilty
to...
Denham the innocent.
they'll never know it was the same person
:D
my total lawyer fees so far equal a total of $0.00 :D
and if i get my way i wont have to go to court even :wink wink
its who u know and a matter of sifting through the cops bullshit statement and letting them know that u know its bullshit and all the bullshit will come out :)
[COLOR=Yellow]Yeah i lose my license for a month in 10 days but it doestn't really mean much any more cause i crashed my car yesterday
What da heck?? Everyone is loosing their license or something, i only got 1 demerit point left till this March before i get it all back so come on ppl take things easy....LOL :D
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
