Don't have a spare?
Most immobilisers can be turned off by turning the key in timing with the flashes.
You should have a card with your immobiliser..or a tag that came with it..with a 4/5 digit number.
Say the number is 1 2 3 4 5
turn the key
wait one flash
turn the key
wait two flashes
turn they key
wait three flashes
you get the idea.
You might be able to get another one made up from anywhere that does alarm installs....no idea on the cost...probably just as cheap as getting a new one installed?
Edited by Nic_A31
https://www.sau.com.au/forums/topic/306290-immobiliser/#findComment-5063922
Yeah mate, try that.
If you stuff it up, turn the key back to OFF and try again.
Remember when you turn they key (after x amount of flashes corresponding to the number), HOLD they key so the light stays on solid, once it's released, let it start flashing again until you need to hold it solid again.
https://www.sau.com.au/forums/topic/306290-immobiliser/#findComment-5063929
Anyone know the legal regulations on keyless starts?
My mothers prado for example just needs the key in the car.
If my immobiliser/alarm could also start the motor without me needing a physical key is this breaking some sort of law/legal regulation?
Reason i ask is my key is so worn that i cant cut a copy off it, i can get another key cut out of the bootlock or something, but you know keyless entry would be cooler.
https://www.sau.com.au/forums/topic/306290-immobiliser/#findComment-5063940
Prado? I think you mean those smart keys...just put them in and go..the car knows when that key is nearby...don't need an immobiliser (button), even to unlock the doors and shit.
They're fine..dunno how, but yeah they're legal.
As for your own, remote starting is illegal.
ok dude but what am i buying and how much is it gonna be?
Didn't work?
New immobiliser + install..couple of hundred at the most, and half a day (if that).
Sure somebody on here can explain to you how to get behind the dash and cut it, so you can drive it in the meantime.
https://www.sau.com.au/forums/topic/306290-immobiliser/#findComment-5063969
    • agreed, the price vs gains it’s there.   unless you go china supercharger. Temu racing anyone?😂https://www.facebook.com/share/15nkfpsg7Z/?mibextid=wwXIfr that was one of the ones that popped up on my feed 😂
    • Bit of a long shot but if anyone has 4 of these laying around in new or near new condition. I will happily buy them off you.     https://skylinespares.com.au/product/stabilizer-door-glass-inner-new-8032404u03/?srsltid=AfmBOop6L5EgUFaHPHiVXoAhv5k8aJYwc77nGmoApp-hY03OiOsNVaOv Thanks
    • I'm wondering is the Toyota and Mazda "collaboration" could see that new Toyota ???G20 ??? turbo engine that they have been showing off recently into a future MX5, apparently it's good for 400hp out of the box That could easily, possibly, be much better than the last collaboration between Toyota and Subaru with the boxer engine in the twins
    • I just watched a Hagerty YT vid on the Rocketeer, with the 3L Ford/Jag AJ V6 in it. I am now sold on the idea.
    • I did look at superchargers for a bit, but from looking, and asking around, IRT the cash outlay and power gains, a turbo has multiple advantages on these little 4 pot engines Either way, boost is not on the cards for my little beastie due to legalities and the cost of getting it legal
