Hey guys,
1993 JZA80 Supra 98,XXX K's Has done 100K service at 94,000K's.
GT35R
PWR Custom 80mm Radiator
PWR Custom Intercooler 115mm with 3" Piping
ARC Cooling Panel
TurboSmart Progate 52mm with Screamer
Stainless Steel 3.5" Exhaust with 1 Hiflow metal cat and 1 rear cannon
Brand New Exedy Twin Plate Hyper Series Clutch (500k's old)
Replaced Getrag Gearbox 500k's ago with low K's box (65,000k's)
Optima Yellow Top Dry Cell Battery
Valve Stem, Front Main, Rear Main Seals all done 500k's ago.
Rays Gramlights 57 PRO Gunmetal Grey
Front: 18x9 +35 / Brand New BF Goodrich 235/40R18
Rear: 18x10 +35 / Pirelli P.Zero Rosso 315/30R18
MVP Front Lip on Stock Front Bar
Blitz Side Skirts and Rear Bar
Car has Series 2 make over - (Rear Lights/Indicators/Headlights/Interior Panels)
Sard 800CC injectors
Bosch 044 Fuel Pump
Aftermarket Rising Rate Fuel Pressure Reg
All Fuel lines are Braided With Speedflow Fittings
All Turbo Lines are Braided with Speedflow Fittings
GReddy Radiator Pipe with Temp Sensor
Twin Thermo Fans Hooked up to Manual Switch
Carbon Fibre Vented Bonnet
EMS 8860 Aftermarket ECU
Lots more things I can't remember
Recaros and No. Plates not included unless trading for another car
Price: $28,000 reg + rwc
Open to trades - stock or modified + cash adjustment (my way if R34 GTR)
Contact James on 0439 318 110 or by email at [email protected]
Pics here: http://www.skylinesaustralia.com/forums/Si...en-t302177.html
Edited by 2JZ35R
https://www.sau.com.au/forums/topic/306297-500bhp-supra-jza80/
  • 4 weeks later...
Price DROP
$23,990 with GramLights no RWC and Reg
$20,990 with no reg no rwc and no Gramlights
(+$1000 for Recaros)
Car is worth more in parts. I calculated car can be parted out at reasonable prices for 28K. I can't part it out due to tennant agreement at my rental property.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
