Hi all...
sorry if this topic has been covered but had a quick search and nothing popped up.
so i have had the RB25 in the car for a while and the motor is sitting fair bit higher than the RB20.
Have swapped to an rb25 cross member and mounts and still sits high, cant get strut brace on, bonnet has been raised at the rear prior to conversion so it still closes..
any suggestions on how to drop the motor as i heard 25 cross member should sort it out.
cheers
Brenton
https://www.sau.com.au/forums/topic/306324-rb25-conversion-sitting-high/
uuummmm pass...
i know that people use them to fit rb25s into 180s, i havnt done the conversion myself
however one of my mates is doing the conversion, he might be able to shed some light on it when he gets on the net tonight
Just use the RB20 rubber mounts and elongate the holes on the cross member so instead of two holes, there is a long slot. Make sure you get the engine close to central when going back in. That should drop the engine by 20mm.
Or put your 32 crossmember back in and just use the RB20 mounts with that.. EASY
hey man
i am also using rb20 mounts for everything, mine fits fine.. for the gearbox i used the rb20 mounts also however ive heard there are 3 types (A,B,C) im using the type b ones and they fit exaclty.
Edited by niran
have heard there is variations on the mounts and cross members for the 20....
i am still running the 20 gearbox... and as said previously was originally running the 20 cross member and mounts and brackets.. but motor was sitting really high with this... was told the 25 cross member and mounts will sit lower... put it in and not so :P
heard someting about cefiro cross member but unsure on truth in this
You are doing something wrong. Your 32 is the same as every other 32 on the planet. Use the Alloy mount brackets or the steel ones from the 20, it doesn't matter. Just make sure you use the RB20 rubber mounts and it will fit properly. The block and head height is identical.
Where is your strut brace touching?
nope nothing is on the wrong side....
find it kinda difficult to do something wrong with it dude....
my thoughts are as previously stated with 3 different types of engine mounts i may have one that sits differently..
when i was speaking to a few mechanics (well known workshops) before i did the conversion they told me that its not uncommon for them to sit high for some reason and it just seems to vary from one to the otehr.. he didnt understand it either.
as i said previously i have tried using both combinations ie all 20 bits and all 25 bits...
both sit high... the strut brace sits on the intake plenum and sits around 10mm or so above the strut tower..
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
