Hi all...
sorry if this topic has been covered but had a quick search and nothing popped up.
so i have had the RB25 in the car for a while and the motor is sitting fair bit higher than the RB20.
Have swapped to an rb25 cross member and mounts and still sits high, cant get strut brace on, bonnet has been raised at the rear prior to conversion so it still closes..
any suggestions on how to drop the motor as i heard 25 cross member should sort it out.
cheers
Brenton
https://www.sau.com.au/forums/topic/306324-rb25-conversion-sitting-high/
uuummmm pass...
i know that people use them to fit rb25s into 180s, i havnt done the conversion myself
however one of my mates is doing the conversion, he might be able to shed some light on it when he gets on the net tonight
Just use the RB20 rubber mounts and elongate the holes on the cross member so instead of two holes, there is a long slot. Make sure you get the engine close to central when going back in. That should drop the engine by 20mm.
Or put your 32 crossmember back in and just use the RB20 mounts with that.. EASY
hey man
i am also using rb20 mounts for everything, mine fits fine.. for the gearbox i used the rb20 mounts also however ive heard there are 3 types (A,B,C) im using the type b ones and they fit exaclty.
Edited by niran
have heard there is variations on the mounts and cross members for the 20....
i am still running the 20 gearbox... and as said previously was originally running the 20 cross member and mounts and brackets.. but motor was sitting really high with this... was told the 25 cross member and mounts will sit lower... put it in and not so :P
heard someting about cefiro cross member but unsure on truth in this
You are doing something wrong. Your 32 is the same as every other 32 on the planet. Use the Alloy mount brackets or the steel ones from the 20, it doesn't matter. Just make sure you use the RB20 rubber mounts and it will fit properly. The block and head height is identical.
Where is your strut brace touching?
nope nothing is on the wrong side....
find it kinda difficult to do something wrong with it dude....
my thoughts are as previously stated with 3 different types of engine mounts i may have one that sits differently..
when i was speaking to a few mechanics (well known workshops) before i did the conversion they told me that its not uncommon for them to sit high for some reason and it just seems to vary from one to the otehr.. he didnt understand it either.
as i said previously i have tried using both combinations ie all 20 bits and all 25 bits...
both sit high... the strut brace sits on the intake plenum and sits around 10mm or so above the strut tower..
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
