1991 Nissan Pulsar RA Gti-R
Reason for sale: Saving for house deposit
Contact: [email protected] or Mobile 0427041658
Price: $11500.00 No RWC Reg till July 10
I have owned and loved this car for over 3 years.
I dont know where to start, so I'm just going to list everything an add details regarding aspects of the car, both known and speculated.
Car is a 1991 RA Model:
145,000kms
Black, with Factory Sunroof. Sunroof seal is in excellent condition.
Paint and body work is in fair condition. The clear is starting to whiten on the roof and on bonnet. Front Left quarter has two shopping trolly dents. Paint has swirl marks and a few large scratches on bonnet and quarters. I suspect that the car has had dent removal done, as clear is starting to wear through onto what looks like bog. Paint has worn on passenger mirror from car cover. Front bar has had center cut, to allow mounting of front mount, also has a crack, which is covered by the number plate, on left hand side of the car.
15 x 6.5 Inch Alloys +38 Offset, Black with Alloy lip. Fair condition. Wheels have had black paint applied over Gold. Alloy lip's clear coat has peeled off most of the surface. Space saver.
Standard Interior.
Drivers seat has had a small tear repaired, Dash is in poor condition, will soon be covered in a dash mat. I have recently recovered the doors in Faux Suede, due to the vinyl originals cracking, No rear Parcel Shelf.
Engine:
Compression, ~145psi per cylinder
Engine is leaking oil from T/C cover.
History: Engine has had a bottom end rebuild at 80,000Kms. I do NOT have any receipts for this build.
Head was reportedly rebuilt, but turned out to be untrue.
I dropped engine at 135,000kms. Engine taken down to long motor.
Full Gasket Kit (Exc Head Gasket), Full Water Hose kit.
Late SR20 Tensioner. New Timing Chain, Guides.
Y-Bracket removed. TMIC Brackets removed along with Oil/Air separator.
Modified thermostat housing.
10 Row Grex oil cooler, with chinese remote filter mount/85 degree thermostat. (Soon to be conjoined with Peter Schurr's Oil Adaptor Plate)
Nismo/Gsport engine mounts. (Awaiting installation)
ECCS:
Standard ECU, rechipped with PLMS series 2 board.(EPROM), tuned by DR Drift, Somerville.
550cc Sard Purple tops.
Bosch Super 4 platinum plugs.
Gearbox:
Standard Flywheel.
Exedy Cushion Button Clutch with New Clutch Fork and Pivot Ball, 135,000kms
Gear box was opened and inspected.
Three sets of shifting springs replaced.
Intake.
Custom alloy airbox, mounted behind FL Headlight.
Drift dry air filter.
Custom 100mm intake pipe to turbo, with silicon hose.
Hybrid FMIC core, custom I/C piping. I/C painted black.
Z32 AFM between I/C and Plenum.
Greddy Type-S BOV
Bleed valve boost control.
All vacum lines replaced.
Exhaust.
Trust T3 Manifold, with 40mm external Gate pipe. This is a very old genuine manifold in Good/Fair condition. Was repaired due to cracking, before a brace was added. Heat Wrapped.
TD06-20g. 10cm Wheel. 100mm inlet.
Trust (Greddy) 38mm External wastegate. 1 bar spring
2 1/4 inch to 3 Inch mild Steel Dump. Dump runs for about 6 inches at 2 1/4 then to full three Inch.
Stainless/Mild 3 Inch system. Exhaust is a bit of a frankenstien, flex between dump and cat, stainless from cat to rear subframe.
F-truck mild steel muffler (Huge) mounted sideways under rear of car.
Suspension.
BC Coilovers, as new. 6kg/mm F, 4 kg/mm R.
Bridgestone Adrenaline, 195-50 R 15. 500Km old
New Front control arm bushes, Sway Bar bushes.
All Original Rear end bushes, soon to be replaced.
Mines Front strut brace.
Brakes.
DBA Slotted Rotors Front, Standard back.
EBC Redstuff up front, bendix OEM replacement rear.
Standard lines.
Brake Stopper (Awating installation)
Misc Mods:
Momo Race Steering wheel, with orignal wheel as spare.
Nismo Gearshifter.
Metal Racing Pedals.
AutoGauge 52mm Boost Gauge.
Spark Plug Cover.
Euro Battery Relocated to the boot, 2 gauge wire
Overview.
When the car was first purchased, it was dynoed at 210kw atw, during an AVO dyno day.
Polished rims coming soon.
Faux Suede Door Cards
TD06-20g.
https://www.sau.com.au/forums/topic/306337-vic-1991-ra-gtir/
  • 1 year later...
Price and Spec Update
Price: $8500.00ono (Priced for Quick Sale) NO RWC, Balance of Remaining Rego.
~160,000ks
Engine:
Nismo/GSpec Engine mounts.
Notes: Engine has a slow leak from the front Main Seal, also needs the Shims redone as they are noisy, Slight Piston Slap when cold due to Forgies
ECCS:
Standard ECU, rechipped with PLMS series 2 daughterboard.(EPROM), tuned by DR Drift, Somerville. Would suit Swap to Nistune
Igniter Moved away from Block
Bosch 984 In-tank pump
Genuine Nismo Adjustable Fuel Regulator
Gearbox:
Replacment G/B installed Approx 12 months Ago (5000ks' / March '10)
Torsen LSD Front Diff
Suspension.
BC Coilovers, 8000 Km Old. 6kg/mm F, 4 kg/mm R.
Bridgestone Adrenaline, 195-50 R 15. 8000km Old Worn on Inside shoulders, due to alignment (possibly need replacement for RWC)
Front Control Arm Bushes, Rear Lower Link and Trailing Arm Bushes Replaced.
Depending on Time of Sale, Rear Subframe bushes will also be replaced
Cusco Front + Rear Strut Braces
Front Sway bar has been Removed for Handling Purposes
Brakes.
QFM A1RM Pads (F) Bendix OEM Replacement ® 0 km old
HEL Braided Lines All Round
Brake Master Cylinder Stopper
Misc Mods:
Good Condition Series 1 Steering Wheel
Euro Battery Relocated to the boot, 2 gauge wire Used with Distribution Block in Engine Bay.
Edited by Rightyothen
For Everyone's information, Future modifications for the car include the following and these will still be going ahead even while the car is for sale.
1: Rear Subframe Bushes will be Replaced; Fuel Tank will be dropped and all the OEM fuel lines will be replaced.
2: Custom made Surge tank (6-700cc) will be installed. Tank will be fed by Walbro 255LPH intank pump, with the Current Bosch 984 becoming the primary EFI pump. Pumps will be powered via 2 x 30 Amp relays straight from the Battery.
3: New Turbosmart Compgate40 Wastgate will be installed. Exhaust Manifold will be modified to suit the V'band Wastegate.
http://www.turbosmartonline.com/index.php?id=574
  • 4 months later...
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
