If I can find the bits I want for my car I'm planning to keep it and do it up. Looking for say 220-230RWKW. Been told so many different things regarding what to do and what not to do but show me what you got.
Turbo kits, something like a GTRS which seems to be a good upgrade from what ive been told
Power FC
Spitfire Coils
Full Manual Conversion for whatever but prefer 33 due to better clutch selection
FMIC
Fuel Pump
Injectors
Reply to thread please
https://www.sau.com.au/forums/topic/306372-wtb-bits-for-r34-skyline-4-door/
Brand New HKS GTRS turbo kit - $3230 delivered.
Brand New Power FC & Commander - $1700.00 delivered.
Brand New Yellow Jackets coil packs - $410.00 delivered.
Brand New HDI/Hybrid FMIC - $570 delivered.
Brand New Tomei Fuel Pump - $470 delivered.
6x Brand New Nismo 555cc injectors - $990 delivered
If you purchase the lot, I can do it for $7000 delivered.
PM me if your keen :D
PM me if your keen :P
PM Sent
  • 4 weeks later...
All I need now is a manual conversion with a clutch and exhaust to suit, prefer non barrel
Come on guys show me what you have...............Cash waiting!
Giulian
ummm i dont have the bits as i just converted my 4dr r34 into a manual... but i picked up a GTST r33 box for 1200 man.. just so you know what price range your looking at... all up cost me just over $2000 in parts with a h/duty clutch aswell...
  • 3 weeks later...
Thanks noely1
I got quoted over $2400 from wreckers in Adelaide (Box, Pedal, master and slave, cross member) but doing some shopping around as well I'm not in that big of a rush to do it I picked up:
R33 Box 90,000ks old and very clean for $1200 with tailshaft, slave and fork and got a cross member with a Nismo mount for $100
Brand new R34 master for $115
R34 pedal with master pin in excellent condition for $150 (didnt want to muck around with an R33 pedal and I know these are hard to find)
All brand new flywheel and clutch bolts from Nissan for around $40
Manual console trims are going for around $100
Dash and steering wheel arent that important to me at this stage unless one come up cheap but thats around $400 the pair.
All I need now it clutch and flywheel which i have priced up around 1K but thats a factory weight brand new chromolly wheel and a good clutch to support the one I want.
So I will fall well below the $2400 price quoted and thats with the dash, wheel and some other bits that those conversions kits didnt come with.
Giulian
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
