Hi
Just wondering if i need to add some more oil since im running a HKS R Type oil cooler. I know std rb25 is 5.5L with filter but i am now running a s15 filter (its smaller) and the extra lines for the cooler
thanks
5.5L :P Pretty sure it is like 4.5L - 5.0L depending how you drain it (warm, cold, vacuum drain, gravity drain etc).
I just fill my cooler up seperately, since I take it off to drain it for an oil change (highly suggest this too, it's really not that hard if it's in an easy to get to place). Then put the usual 4.5 litres or so then run the car, let it cool down and then check the dipstick.
  • 1 year later...
sorry to dig up a new thread, im flushing my engine oil. wondering how much to re-fill
the oil in there has only done 30 dyno runs as it was used to just flush and clean the engine.
i found the norm is 4.5l for the engine, say 500ml for cooler +some for lines.
now im taking it to the track monday. so i was told to overfill.
how much would i put in? 5.5L? 6L?
stock sump btw
my 25 with hks type s cooler takes 6L abouts, I know its more than a single 5L oil container
oh yeah thats mounted in passenger side as well...
Edited by 75coupe
fill it to the hump on the dipstick, start it and let it run for a bit, then check the level again
no one can give you an amount in litres as it varies, mostly on how much oil was drained, ie is the cooler completely empty?
  • 3 weeks later...
Hi guys,
everyone is saying to put in extra oil then start the car and let it run, do i assume let it run all the way to operating temp as the HKS oil cooler has a thermostat built in meaning it will not fill the cooler until the thermostat opens.... this would mean your overfull until this opens correct?
Also wondering how the oil would drain from the cooler knowing that it is lower than the lines running to the oil filter and by means of gravity the oil would remain in the cooler?
sorry if these are noob questions my logic could be way off, i am looking at putting a cooler on very soon and have never had one to know the answers.
It doesn't unless you remove the oil cooler and pour it out.
Also most oil thermostats don't completely block of The oil cooler so it should start to fill as soon as you crank the engine.
When fitting new oil cooler kits I always disconnect the ignitor and fuel pump fuse and crank the engine for a while to pre fill the lines and cooler so the engine sees oil sooner rather than later when u fire it up properly
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
    • Yeah, but "restomod" implies Singer and things like it, which implies drug money / trust fund maturity.
