Anyone has it on ps3?
Yeah!
I bought the one that came in a "tin" texture case.
A pic of the Alien on the front and Predator on the back.
Finished all 3 single player campaigns, they were too short IMO.
Same Finished it twice.
Short but intense.
The Predator would be a bit overwhelming for the beginners on controls as there is a lot to do, but I played Predator Concrete Jungle on PS2 and that had just as many controls, so I was use to it.
Game play wise, the Alien is most smoothest (Quickest)
Predator, quite technical.
Marines, is probably the most scariest out of the 3, as it keeps you in suspense.
Overall it is a good game and keeps me busy.
https://www.sau.com.au/forums/topic/306428-avp/page/3/#findComment-5140781
  • Replies 42
Yeah i just finished on Predator and Alien, prob start human later on, i heard is a bit freakie lol, overall i rate the game, something different, has anyone played it online yet?
Yeah it is man!
Cuz of all the Darkness you have to go through.
Aliens just jump out of no where.
You will have to heavily rely on your Motion Tracker.
VP78 Pistol Hand Gun is surprisingly decent.
ZX-76 Shotgun is best for blasting the Aliens away as it is also a double barrel shot gun.
The M41A/2 Pulse Rifle / Grenade Launcher is nuts but you need a very good aim as the aliens can take a bit of a spray until their down.
M260B Flamethrower is good for frying the Alien Eggs and Face Hugger's but runs out too quickly.
M42C Scoped Rifle (Sniper Rifle) is best for taking out the enemies from long range and can be used up close, packs quite a punch too! (6 rounds per Magazine so keep track on the ammo level and reload frequently).
M59/B Smartgun is the Marine’s primary heavy-fire support weapon.
Auto-targeting or free-fire modes.
As long the enemy is in the target area on the screen, it will accurately fire at them.
It’s an excellent weapon to use against fast moving enemies like Aliens or against cloaked Predators.
It takes up both of your primary weapon slots so you’ll need to find another weapon when your ammo is running low.
You also can’t run anywhere when you’re carrying this weapon.
Use your Torch (Flash Light) in dark areas as light is your friend and the Aliens weakness. (As for Alien Darkness is your friend, Humans weakness).
A good strategy is using the R1 button to knock the Alien down and your weapon will Auto Aim at its head and take'em out that way.
Again, Shot gun best for this.
Lean up against walls to avoid attacks from behind, in building areas.
Use Stims to replenish your health, Flares to give more light, when you see Sentry Guns, activate it to help destroy the Aliens and you will have a Hacking Device to enter buildings / enabling power to places.
Good Luck Marine! :ermm:
https://www.sau.com.au/forums/topic/306428-avp/page/3/#findComment-5145691
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
