Hi guys,
I have bought some s/h 600cc top feed injectors and flow tested them at my workshop and got the results below (all i know is, they are black, says 'siemens' on the side and previous owner THINKS they are sards.. if anyone has a better guess, let me know lol)
now, im new to the injector flow testing show so i would like some educated input, as to wether these results are ok, or if these will need further attention before installation (ie, ultrasonic clean etc)
to me, these results seem ok except for 1 injector that seems to be spraying about 5% more than all the rest, should i be worried?
thanks
https://www.sau.com.au/forums/topic/306450-injector-flow-test-results/
a tad over 2bar, maybe 2.2 bar ?
they look exactly like this
http://www.sxd.com.au/Sxd/Siemens60lb_injectors.html
anyone have good or bad experiences with these?
Edited by snozzle
can you test them at 3 bar? yeah and as R32 TT said, if that injector does seem to flow a bit more than the rest, mark it and put it in number 6
I'd get them sonic cleaned, just to be sure. They might all be a bit crappy, and will only get worse.
These two guys know what they are on about.
I'd get them sonic tested, and then if one still flows more, put it in number 6. Put the second highest flowing one in number 5.
ive had endless dramas (poor control) with certain siemens in our applications (nissan remaps and pfc etc) they are pretty poor (due to a large bad batch early on). There is a set floating around on here that has been through my shop door twice and they were supposed to be 600cc and intended for R34 so be aware.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
