Hi Guys.....
Just wondering if anyone knows or has info to help me. I lost my license in November for DD and get it back at the end of March. When i lost it i was on my Opens for 2 months.
I have been told that when i get my license back i go back on green P's and ahve to wear the green P plates etc...
When i was on my P's orginally i got it before the P'pates rules about drving turbo cars and wearing the plates came in..
Any clarification would be great
https://www.sau.com.au/forums/topic/306468-getting-license-back/
You know it's ALOT easier calling QLD transport and getting the 100% correct answer, then reading hear-say on a forum.
If you lost an open license you get an open license back*, unless something has changed - refer to calling QLD transport.
now i'm not 100% sure about this, and you would be best of checking with qld transport, but i do recall a mate of mine having a whinge when he lost his licence a few years back that he wouldn't be able to drive his 180sx when he got his licence back because he had to be on his p's for 6 or 12 months after getting his licence back (despite having been on his opens before he lost his licence) and the vehicle restrictions were going to apply to him (this was when they first brought them in in qld).
yeah i'd check with qld transport cause my mates misses lost her licence and when she got it back she was on green p's.. however i would clarify
Iust spoke with QT and was advised that i go back onto my green P's for 12months.
Cant drive between 11pm-5am
0.00 Alcohol limit
4 points instead of 12
I also asked about being able to drive turbo cars and V8's and they said that you can still drive these vehicles
Also you dont need to display green P plates
0.00 Alcohol limit
ouch dude - gonna be a long 12 months. in the most nicest way possible, hope you learned a lesson :)
QTF
afaik as long as turbo is stock in qld you can drive one. You shouldn't go down from Open to P's even if done for DD....
I'm gonna look into that tomorrow
In future just call 13 23 80, it's not a good idea letting everyone on the forum know that you were done for Drink Driving :)
Thats the number i called.... Unfortunately it was a dumb option and poor lack of judgement which will not happen again..
QTF
Supposedly now if you loose your license be it by DD or loss of demerit points you go back to a 12 P license even if you had your opens when it was lost
QTF
Just called Queensland Transport then;
If you have had your license cancelled, EG: DD, you went to court and it was ruled you get a cancellation for 6months for example, then yes you would go back to P’s for 12 months.
However, if your license was suspended, say from loss of points then no, you do not get put back onto your P’s.
Straight from QLD transport
If you have had your license cancelled, EG: DD, you went to court and it was ruled you get a cancellation for 6months for example, then yes you would go back to P's for 12 months.
However, if your license was suspended, say from loss of points then no, you do not get put back onto your P's.
Thats weird cause my make lost his lincense by points and went back to these P rules, however things may have changed i guess... Good to know
i got done for some silly driving and got done for dangerous driving, pritty poor effort mind you.. court disqual and i got my licence before all that crap to...
no restrictions apart from that
11pm-5am thing on 1 point
almost off them.. :D cant wait for last year of p's
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
