Hi,
For sale here is a RB20 Engine and Gearbox removed from a 1990 R32 GTSt with 108,000kms shown on the clock.
The engine is extremely healthy with no smoke, bottom end knocks or funny noises. Only street use tuned safely to 190kW by Trent at Status Tuning. Oil and filter always changed on a regular basis.
It includes:
Long motor from rockers to sump
Inlet side complete inc Injectors etc
Crank Angle Sensor
Exhaust manifold (not fitted)
It doesnt include:
ECU Loom
Coilpacks
Turbo and Water/Oil lines
Crossover Pipe
Its worth noting that there are NO broken studs in the head for the exhaust manifold, as this is a given when removing RB exhaust manifolds.
Price: $800
Also for sale is a RB20 gearbox removed from the same car.
The bearings are quiet, no input shaft bearing noise (common) the synchros are in good nick apart from a light notchiness shifting quickly to 4th and 5th at higher rpm but at lower rpm its fine. This could be partially rectified by using Redline Lightweight Shockproof oil.
Price: $400
Parts are located in Melbourne, prefer local pickup but shipping can be arranged.
Cheers,
Mat.
0400 558 030
https://www.sau.com.au/forums/topic/306476-r32-rb20det-engine-and-gearbox/
The engine is a Silver Top model.
No compression tests were done because the engine ran like clockwork upon removal, and had no trouble making the power at Status.
The engine and box have been removed only due to full 25 conversion.
Hey mate,
I have a HR31 Coupe, am interested in putting this motor in, as ive had enough with my standard REDTOP NICS ENGINE...
Just have a few Questions....
What will i need to do a complete engine swap? as you said you dont have some parts...
Cheers,
Pana
I have no idea exactly what you need to fit this into your 31 but to get this engine running alone you need:
Turbo and Water Lines
ECU Loom
ECU
Coilpacks
Coilpack Loom
Starter/Alt Loom (could use yours maybe)
Alternator (maybe use yours??)
Ignitor
Crossover Pipe with BOV
Engine mounts
Power Steering Pump (maybe use yours??)
Its alot of stuff but its not...all easy stuff to find. Some of it I may be able to help with.
    • That's f**ked up. I'd guess it's more likely that you have an entire S13 subframe in there. Does it still have HICAS mounting points? Seeing as it is quite possible that yours is the only such converted car in the world, you'll probably struggle to find someone who can tell you from direct experience. 'Twere I you, I'd be looking for 4 stud Skyline rear brakes and convert back. At a minimum. Preferably go find all the stuff you need to put it back to 5 stud (assuming you're happy to change wheels) and upgrade to some decent brakes. You don't even need much stock stuff. Don't need calipers or rotors, as you can go fully aftermarket. Just needs hubs and the other bits and bobs that are different to what you have now.
    • The engine has nothing to do with it. The physical space behind the headlight is the limiting factor. And the height. The height of the NS70 is the same as stock. So the clamp bar across the top goes on nice. The battery tray is big enough for it to sit on. The X is for extra capacity - it has even more lead in it than the non-X NS70. Heavy f**ker. But it's not a track car, so I will suffer a couple of extra kg. In the case of the R34, maybe the physical space there is not as deep (forward-backward, not up down). Hence why they say the 60 is the biggest. But I would never trust a catalogue to tell me what will fit. I have the car. I have the existing battery. I have the tape measure. I have the dimensions of all the available batteries. I find the biggest box that will go in. (With the right terminals in the right places, of course).
    • Hello! I have been having a hard time finding the answer to this question… I have a R32 GTS-T Sedan than has been 4 lug swapped using S13 hubs, rotors, and brakes. The front has also been converted to S13 suspension.    When the swap was completed, the handbrake cables were never hooked up, as the S13 rear calipers are the “handbrake”, and not the typical drum on rotor that the R chassis are. Does anyone know handbrake cables that will work for this conversion? I’d like to not use a hydraulic handbrake and stick with the traditional cable style. My original thoughts were to go with S14 cables and try to make them work, since I’m pretty sure S13 cables will be too short.    Any help would be appreciated!
    • I did some research, considering you have a neo engine, how is that battery compatible? I checked centuries website and super cheap and says it's not compatible. Only this full size one is. https://www.centurybatteries.com.au/products/ns60-mf
    • No, lets be honest here. I went to Winton and did a track day, for all the mods and V8 power and craziness I posted up a time that a K24 stock motor Honda Accord can do on the same tyres (narrower, too) 250kw and learning how to drive the f**kin thing is the sweet spot.
