Hello,
Ive got an R34 RB25DET Neo motor, i put an R33 RB26DETT Crank & rods in it, and need help with piston selection.
The neo head has a CC of 51.5 which is smaller than the standard rb25, and way smaller than the rb26.
I bought rb26 pistons (87mm bore which my block has been bored out to) and after installing them, did compression ratio calculations and am getting something around 11:1.
Just wondering if anyone has some insight on this!
Thanks guys,
John m
Raleigh, North carolina, USA (S14 RB25 Neo)
what head gasket? and put up ypur calculations and someone will show you
Cylinder Bore Size 87
Piston Stroke Length 73.7
Head Gasket Bore Diameter 88
Compressed Head Gasket Thickness 1.2
Combustion Chamber Volume In CCs 51.5
Piston Dome Volume In CCs Negative For Dished Pistons (Use '-') 15.5
Piston Deck Clearance Negative If ABOVE Deck (Use '-') : -0.5715
(when using 87mm rb26 8.5:1 cp piston with Compression height of 1.193)
right now its at 11.9:1
I think im pretty much screwed on the Neo head + RB26 crank & piston combo. I thnk ill have to either
A. sell the neo head and go for the larger CC standard rb25 head
B. sell the whole built short block and get a bone stock neo bottom end and throw my neo head on it.
Opinions? help?
-Thx
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
