Hey guys
I have power to my digital air fuel gauge, I just have no idea where to hook it up to. Help would be appreciated.
Cheers
When you say you have "power" do you mean you have wired it in eg: power/signal/ground???
I have ground and power hooked up so it lights up etc... I just don't know where to wire in the signal.
Middle wire of your o2 and you should be right.
Craved beat me to it :P
Edited by grandmasterb
interesting.. would this be the same for 34 O2 sensor..
(as in will it be the middle wire?)
Yeah mate still the same just a different part number for R34 GT, R34 GT-t, Stagea WC34 (RB25DE/Neo 6) WC34 (RB25DET/Neo 6)
From memory they have 2 white and one black but you'd have to look at yours to double check :D
got a wiring diagram? i tried that before.. asked if there was a wring diagram.. i got a pfc btw.. although dont think that should make a difference..
and thanks grandmaster.. i know the part # diff etc.. was wondering if the wire to splice would still def be the middle wire..
Would figure it would be easier to splice a wire in from the O2 sensor at the ECU though personally (that's what i did)
For simplicity sake i've always gone from the actually o2 as i've never trusted the wiring diagrams i've had and some of the cars i've worked on the wiring harness has been chopped that much its not funny. Personally preference at the end of the day.
As above, i've got a wiring diagram for the GTT so i'll dig it out and post it up for you :happy:
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
